Trailer mounted camera help
Old Feb 25, 2018 | 06:51 PM
Bill_The_PA's Avatar
Bill_The_PA
Ok I’m a little confused. Since I’ve joined in on the conversation (last 1/2 hr or so) you have found the 12 pin wires that were zip tied around the spare tire. You’ve plugged those wires into the new harness and you’ve plugged the 40 foot harness that runs from the camera; checking those connections as well ( ito camera and where it branches to the TPMS Module)
Old Feb 25, 2018 | 06:56 PM
Bill_The_PA
Oh there is my last post.
Old Feb 25, 2018 | 06:57 PM
SmokyOkie's Avatar
SmokyOkie
The nly connection between the pigtail and the camera appears to be where the camera cable plugs into the final pigtail harness, and that connection seems to be tight. I didn't do the install on the trailer, the trailer builder did, but I traced the entire routing of the cable and didn't see any loose connections
Old Feb 25, 2018 | 06:58 PM
SmokyOkie's Avatar
SmokyOkie
Originally Posted by Bill_The_PA
I’ve seem to lost the last post I made.
Again in the past 1/2 hour you have found a harness zip tied to the frame and used it
Yes I did. That was done before I tried to use the camera
Old Feb 25, 2018 | 07:02 PM
Bill_The_PA
Well I have no idea. If your using the zipped up12 pin wires then I’m at a loss. Sorry I couldn’t be more helpful.
Old Feb 25, 2018 | 07:06 PM
SmokyOkie's Avatar
SmokyOkie
Thanks Bill! I was hoping someone had a link to the owners manual so I could print it out and look for trouble shooting tips.
Old Feb 25, 2018 | 07:28 PM
Bill_The_PA
that wire harness being hidden is usually where thing get delayed.
Found this
Matt Gieselman | 2017 Ford Super Duty Trailer TPMS Install
Old Feb 25, 2018 | 07:44 PM
SmokyOkie's Avatar
SmokyOkie
Found this
Matt Gieselman 2017 Ford Super Duty Trailer TPMS Install
Thanks for the link. The evidently sense the TPMS because trailer set up calls for it. I haven't had the sensors installed yet so I skipped that part of the trailer set up. I wonder why it senses the TPMS but not the camera.
Old Feb 25, 2018 | 07:52 PM
JetFuelBurner's Avatar
JetFuelBurner
Install Instructions attachment
Hope this works. I found it on another thread. Tried to save it only to find out I apparently already had it. Here goes...
File Type: pdf
Old Feb 25, 2018 | 07:53 PM
Bill_The_PA
Only thing I would suggest is check power and continuity at the camera end. Simple light tester will at least ensure you have power. Then check the ohms
Old Feb 25, 2018 | 07:54 PM
JetFuelBurner
I decided not to screw with it. Letting my trailer dealer do the camper wiring. Will have my truck dealer do the truck wiring and then we'll see if it all comes together. I'm not crazy. Trailer is stored at the In-laws farm 10 hrs away.
Old Feb 25, 2018 | 08:09 PM
SmokyOkie's Avatar
SmokyOkie
I am like you, I had the trailer builder install the trailer side. I helped his man do the truck side. I am pretty sure the truck side is right. I mean, if the truck is sensing the TPMS but not the camera, it almost has to be the camera side somewhere.
Old Feb 25, 2018 | 08:10 PM
  #28
SmokyOkie's Avatar
SmokyOkie
Thank you!
Old Feb 25, 2018 | 08:11 PM
  #29
SmokyOkie's Avatar
SmokyOkie
Thanks Bill!
Old Feb 26, 2018 | 06:16 AM
  #30
Xwild's Avatar
Xwild
Verify the connector at the camera is actually plugged in. It connects inside the housing, so it's a little wierd to make the connection.. not hard, just weird.
