Will not start
Old Feb 25, 2018 | 01:16 PM
spaytons's Avatar
spaytons
Will not start
I've checked a number of threads and didn't see what I'm looking for. If you know the one I need and can point me at it, great.
89 F150 In line 6
Is there a for sure way of checking the fuel pump? I don't have access to a gauge. When I press the pressure relief valve fuel squirts out. Funds are tight and I don't wish to throw down $80 at some thing that may not be faulty.
It will fire up if I spray starter fluid in it.
Background
-20 degrees, fuel very low. Fill up and include HEET. Drive to work. Drive home. Hour later starts, then dies.
Next morning, starts with a jump. Drive to work. Later, starts then dies.
The next morning started with jump. Drive to my shop, will not start after shutting it off.
Got the truck into a heated shop in the hopes that I got froze water in lines.
Now it won't start even with a jump.
I've changed the filter and plugs. Checked pump ground. I hear clicks when I turn ignition.
Is there anything else I can check and is there a FOR SURE method to check the pump?
Thanks in advance.
Old Feb 25, 2018 | 01:20 PM
Da_Lariat_Chariot's Avatar
Da_Lariat_Chariot
If you want to make sure the pump is producing on-spec pressure/flow you NEED a pressure gauge. It would also help to check any codes stored in the computer. If unsure, Google 'eec-iv codes paper clip' and you will find some step by step tutorials.
Old Feb 25, 2018 | 01:33 PM
spaytons's Avatar
spaytons
I'm hoping a friend has one I can use. But I won't know until later this week.
I saw a video were you can jump the test connector and count the engine light as it turns on and off for a code.
Old Feb 25, 2018 | 01:38 PM
Da_Lariat_Chariot
That is indeed the 'paperclip' method. It will work, just count all the flashes you see and note the pauses in between and we can help decode the rest.
Old Feb 25, 2018 | 02:01 PM
willowbilly3's Avatar
willowbilly3
I ordered on of those $18 fuel pressure gauges on ebay and had it in a couple days. I also have an 89. I can hear the pumps cycle and have some pressure at the schraeder valve but it looks weak.
Old Feb 25, 2018 | 02:07 PM
yardbird's Avatar
yardbird
You can also get a fuel pressure gauge at Autozone with their "tool loaner" program. That's how I did the final diagnosis on my Mercury.
Old Feb 25, 2018 | 05:32 PM
spaytons's Avatar
spaytons
I had forgotten about the loaner stuff. Thanks for the reminder. Pressure very low
Old Feb 25, 2018 | 05:39 PM
spaytons's Avatar
spaytons
If I read it correctly, all the codes I saw probably was because the engine wasn't running. Everything points to the pump. But not 100% certain.
Screw it. Gonna replace the pump. let you know
I hate the hit and miss method.
I don't know how many times I've replaced a costly part and it turned out not to be the problem,
Old Feb 25, 2018 | 05:42 PM
Mudsport96's Avatar
Mudsport96
Could also be the pressure regulator.
Old Feb 25, 2018 | 06:44 PM
joey2fords's Avatar
joey2fords
it might be helpful if you posted the codes that you got. so far, nothing actually points to the pump ... the pump may be a good guess, but that's all it is at this point. if you hate throwing away money and don't want to undertake a fairly big job that may not provide a fix you should post codes and check fuel pressure with a gauge.
Old Feb 25, 2018 | 07:25 PM
spaytons's Avatar
spaytons
67- went away when I pressed the clutch
13- RPM unable to reach lower test limit
23- TP sensor out of range
32- EVP voltage below closed limit
Checked engine light 4 times. One code may have been 213- Spout circuit open.
Going off of codes in a CHILTON manual. Not a fan of theirs.
Old Feb 25, 2018 | 07:39 PM
spaytons's Avatar
spaytons
Fuel comes out of the pressure relief valve when I press it. The gauge says its not even 9 psi
Rob Frank
Jul 28, 2019 10:35 PM
jwandell
1997 - 2003 F150
Apr 25, 2018 08:18 PM
tubby12729
Sep 4, 2012 09:41 PM
thebeast150
20
Sep 20, 2009 10:49 PM
TRUE IMAGE
Nov 25, 2006 04:08 PM
