T case hitting cab while hitting bumps
Old Feb 24, 2018 | 09:34 PM
Dutter 2's Avatar
Dutter 2
On 96 f250 when ever I have a hard shift or hit big bumps I feel my t case hitting the cab and I can see where it’s been hitting. The trucks a extra cab. Has anyone else ran into this problem?
Old Feb 24, 2018 | 10:03 PM
Azryael's Avatar
Azryael
Sounds like the transmission mount is bad and your whole driveline is flopping all over the place, which seems to me like it would be a lot devastating than that, and your driveshaft would have certainly let you know it's dealing with some unusual torque.
I'm looking at mine right now and it's solid, doesn't move no matter how hard I push on it.
I'm assuming you have a married transfer case that sits directly behind your transmission.
Old Feb 24, 2018 | 10:06 PM
Dutter 2's Avatar
Dutter 2
Yep I tried to pry on it but she wouldn’t move even with a oil leak dripping on it
Old Feb 24, 2018 | 10:14 PM
Azryael's Avatar
Azryael
I'm assuming your mount is okay then.
How are the cab mounts? Could be sagging a little bit, but that just seems like excessive play for it to be moving around like that.
Old Feb 24, 2018 | 10:29 PM
Dutter 2's Avatar
Dutter 2
I looked at my cab mounts and they look to be fine no big cracks. Idk if there’s a spec on how much there supposed to be squished
Old Feb 25, 2018 | 12:48 AM
88n94's Avatar
88n94
What about the motor mounts? What about the transmission mount cross piece that runs between the frame halves?
What engine and transmission do you have?
Old Feb 25, 2018 | 10:14 AM
Dutter 2's Avatar
Dutter 2
Haven’t checked my motor mounts yet and I have the e4od and 7.3 powerstroke
Old Feb 25, 2018 | 11:42 AM
Lead Head's Avatar
Lead Head
Either bad transmission mount or bad cab mounts. Really no other possible way unless your cab is rotten and sagging.
Old Feb 25, 2018 | 01:41 PM
Dutter 2's Avatar
Dutter 2
Yeah that’s what I’m thinking. Just seeing if anyone else has had this issue and fixed it
Old Feb 25, 2018 | 02:58 PM
F350 1990's Avatar
F350 1990
Time to lift that cab put new bushings,bumpers, plus trans mount etc --- Energy Suspension kits aren't half bad ---doing one right now on one of my restoration projects.
Old Feb 25, 2018 | 03:13 PM
95fiveoh's Avatar
95fiveoh
I used the Energy Suspension Kit on my truck. I'm satisfied with it.
Old Feb 25, 2018 | 08:34 PM
Dutter 2's Avatar
Dutter 2
Is that polyurethane or rubber ? Cus my truck already rides like a tank lol
Old Feb 25, 2018 | 08:38 PM
95fiveoh's Avatar
95fiveoh
It's polyurethane, but personally I don't think it feels any harsher than rubber.
F-250 WARHORSE
Jan 15, 2017 03:28 PM
torreselect10
Mar 11, 2015 12:14 AM
palmer77crew
Nov 15, 2010 02:08 PM
KSims1868
Jun 22, 2005 12:21 PM
mickelsons
Dec 8, 2001 12:23 PM
