In-dash A/C
I'd like a fresh air system with a filter and the recirc option.
Vintage Air sells a "complete" system without the pulleys and brackets. Those pieces can be hard to find. I urge anyone contemplating this addition to scrounge all the pieces from the relevant engine and to take photos before removing them, like I ... did not do.
Eric
Eric
Eric
Eric
I just bought a Vintage Air kit for my 64. I'm just about done with disassembly of the old components. I too would prefer a "factory air" look. My truck doesn't have a radio, but I haven't decided if I want to cut into the dash to mount the center vents. I would really like to mount the left and right vents in the dash where the kick panel vent controls are, but I can't do the welding or bodywork myself. So maybe at a later date.
I do think that I can mount the 3 **** controls in the dash where the choke, heater, and in my case blank hole are. I did a preliminary check and it looks like there is enough room behind the dash to mount them. Won't know for sure though until I try them. I don't know yet what I would do for bezels yet either.
Yes the vents that come with the VA kits are pretty plain looking, but they have nicer vents available too. As do other A/C suppliers and street rod parts manufacturers. I've seen some angled housings that could mount on the bottom part of the dash and point the vents upward. That would still require cutting holes in the dash but not on the face.
I still have a lot of research to do to figure out how I'm going to tackle it.
I had no problem cutting my dash. I really dislike the look of those under dash Louvers. I chose the vintage air system and chose my own components using only their 66 f series condenser kit...pieced the remainder. Installed the controls where the radio used to be. I'll post pics when I get home later.
Thanks!
Nordi:
I would have to dig out all my receipts to figure the total cost but, suffice to say, it will be more expensive to buy the components than a ready-made kit. However, a "custom" install is what I was after. The only "kit" I bought from Vintage Air was their 1966Ford F-100 condenser kit with drier. I didn't use the entire kit, because I mounted the drier under the battery box rather than under the inner fender. I didn't want to run the hoses under the fender and then out again to the firewall. I did use their condenser mounts and the modification to the hood pull, which was convenient. I got a ComPac Gen II unit because it was the largest that I could fit under the dash, behind the glovebox. We made a bracket/cradle so that the AC hoses were pre-connected to a bulkhead fitting and the whole unit mounts to the firewall through the original holes, with two additional supporting tabs under the glovebox door. Pre-connected the heater hoses to a bulkhead fitting as well, so all other connections can be made from the engine side. Got the Sanden compressor from Vintage Air as well as the deluxe control panel that you see....and about two years ago, snagged a really nice FE/Sanden compressor mount kit with an idler pulley. All the brackets were 3/16" steel plate and I got it for a fraction of the original cost....no longer available from the manufacturer, but a nice set up.
Resonateur,
THANK YOU for all the info! I had a feeling it was a Gen 2 System by the controls you used. Once again, very nice install. I can appreciate you being so meticulous because I am the same. I’m going to be using a full Explorer GT40P engine with the FS10 compressor. I called Vintage Air and they said it will work fine with the system and they sell an adapter block for the compressor to convert to Sanden type lines. Looks like I’ll be piecing a system together too!
Nordi,
With your FS10 compressor, you might consider adapting the Crown Vic system to your truck similar to what these guys are doing:
1964-viccup-build
May be a cost savings, maybe not. Worth a look though - Crown Vics have inexpensive, reliable systems and can be found in every wrecking yard everywhere.
1964-viccup-build
Tyler S
22
02-26-2014 09:22 PM
coolblue66
07-10-2003 12:59 AM
