Add a leafs?
Old Feb 24, 2018 | 02:51 AM
Phoenix02's Avatar
Phoenix02
In doing some further research here, it seems the answer to my question is to go with stock Excursion shocks in the rear and F250 shocks on the front, which will be running slightly compressed with my existing shocks but then be exactly where I want them when I swap to V codes.
Is this the way to go?
Old Feb 24, 2018 | 07:54 AM
pirate4x4_camo's Avatar
pirate4x4_camo
Length wise that might fit but that is unknown to me.
However if your goal is improved handeling that is a poor choice of shocks.
Most shocks nodays are valved specific to the application and a pickup truck is going to have lighter valving then a Excursion.
Old Feb 24, 2018 | 08:03 AM
pirate4x4_camo
If you click on the part number it has the compressed and extended shock length.
Bilstein - KYB - Rancho - Monroe - KONI Shocks and Struts - Shockwarehouse.com
Old Feb 24, 2018 | 09:57 AM
ShelbyHauler's Avatar
ShelbyHauler
Originally Posted by pirate4x4_camo
I was replying to the original poster of this thread.
Apologies, you did not specify.
Old Feb 24, 2018 | 03:36 PM
pirate4x4_camo
No worries, just wanted to make sure the op knew I was answering his question. I didn't reply to you simply because you had clearly stated you were trying to increase the spring rate which is what add a leafs do.
Old Feb 24, 2018 | 05:57 PM
ArmyLifer's Avatar
ArmyLifer
Originally Posted by Phoenix02
Ok, I'll go for the factory style bump stops instead.
Will the KYB Monomax work with a mild lift, like what you get with the spring swap, or would I have to buy all new again when I do the swap? That was one of the things that drew me to the Skyjackers- they said they would work with 0-3" of lift, so I figured they would work stock as well as with the slight lift from the V/B swap.
I’ve got the KYB Monomax (at Pirate’s suggestion) with my ATS V’s and C’s. Those springs give me a 1.5-2” lift over stock height and the shocks work fine.
Old Feb 24, 2018 | 07:17 PM
Phoenix02's Avatar
Phoenix02
Thanks, that's exactly what I was looking for. Just bought the Dorman bumpers, will get some Monomaxes this week and keep an eye out for some springs at a later date. Will probably add a leaf to the rear to compensate when towing heavy later this year.
groesener
Jun 18, 2022 02:29 AM
BMXpert23
Aug 3, 2017 01:48 PM
Tiny2003Excursion
Apr 9, 2015 11:18 PM
Rainmaker68
Nov 23, 2012 12:26 AM
monstertrucker
Jul 9, 2008 07:38 AM
