Headlight adjustment?
Old Feb 23, 2018 | 07:24 AM
Alex from GA's Avatar
Alex from GA
'99 Explorer. There is a small hex head adjustment screw sticking up on each side which I gather is the vertical adjustment. What tool do you use and which way to turn to move the beam up? Thanks.
Old Feb 24, 2018 | 08:11 AM
steve(ill)'s Avatar
steve(ill)
you can use a very very small socket.......... or I think there is a special tool , just a tee handle with a built in hex drive .. 4mm ?... probably available at Auto Stores. Park 20 ft from the garage door and at night turn the screw 1 turn and watch the light move on the garage door.. Just turn 2 turns, then test on the road. Keep track of the change so you can move it back if you go too far.
Kountryguy
Mar 8, 2019 09:19 AM
weyland426
Dec 18, 2009 02:02 PM
charliedana
Nov 12, 2008 08:18 PM
rmilchman
Feb 29, 2008 12:37 PM
ohiowhitetail
General Automotive Discussion
Oct 26, 2004 07:32 PM
