Sponsored by: Real Truck
Head light adjustment
Old Nov 11, 2008 | 09:55 PM
charliedana's Avatar
charliedana
Hi all I just took out a 2.5" block out of the back of my 2004 superduty and now need to adjust the headlights any help to do it right the first time
thanks
Old Nov 11, 2008 | 11:20 PM
patrickke's Avatar
patrickke
pull your truck up to a garage door, get a phillips head or 5/16 nut driver and adjust to probably the middle of the door bc you probably have fogs ur headlights should be rt on top of your fogs....its really simple to adjust
Old Nov 12, 2008 | 08:18 PM
miker67's Avatar
miker67
On LEVEL ground, face a door such as a garage door. Park the truck 25 feet away. Measure from the ground to the center of the headlights. Go to the door. The top of the headlight spread should be approximately 2 inches lower than the measurement you took at the truck from the center of the headlights.
