I am guessing that transmission uses the small bell housing bolt pattern and if so then I would think it would bolt to any small block bell housing bolt pattern block.
Do you know what model it is, C4/C6/AOD?
Also how do you know "it works great"? Did you pull it from a running/driving truck and drove it before you pulled it or because the seller said "it works great"?
One I would trust the other not so much, guess what one is what
Dave ----
