bolt pattern 351c vs 400M
Old Aug 1, 2005 | 01:12 PM
lisagoud's Avatar
lisagoud
Unhappy bolt pattern 351c vs 400M
I was always told that the 351Cleveland was the same bell hjousing bolt pattern as the rest of this series.....351M, 400M, 426, and 460...am I right?
Old Aug 1, 2005 | 04:48 PM
mark a.'s Avatar
mark a.
No, a Cleveland uses the small block bolt patern.
Old Aug 1, 2005 | 05:09 PM
lisagoud's Avatar
lisagoud
so I found out today...anyone have access to translate Ford numbers:
I found a auto tranny marked RF-E0AP-7A105-AA which will bolt up to the 351C.
I had wanted to use a much heavier duty tranny numbered:
RF-C8AP-7A105-A.
Can anyone tell me what each tranny is (I know the later is a c-4 1968 series)> Does anyone have a bellhousing for the later that will fit a small block (4 bolt bellhousing)
Old Aug 1, 2005 | 05:24 PM
go_racing84's Avatar
go_racing84
A little info I found here
https://www.ford-trucks.com/article/...ers_Guide.html
And elsewhere on the web indicates that the E0AP unit is either an AOD or AODE.
In the other case, if you indeed have a C4, it should not be hard to find a small-block bellhousing for it. In fact, there is at least one on ebay right now (search "c4 bellhousing").
hollenjoe
Jan 17, 2014 11:06 AM
Cods81bronco
Jun 1, 2012 12:15 PM
401477534
16
Sep 10, 2011 04:00 PM
460/5
23
Nov 18, 2009 04:49 PM
lisagoud
Aug 2, 2005 12:10 PM
