Bellhousing bolt question
Old Aug 1, 2005 | 01:15 PM
lisagoud's Avatar
lisagoud
a 351 Windsor is the same bolt pattern as the rest of the series-----302, 289, etc.
A 351 Clevand is the same bellhousing bolt pattrern as theest of their series (3350...351M, 400M, 426, and 260...correct????
Old Aug 1, 2005 | 02:33 PM
ronclark's Avatar
ronclark
No. The cleveland uses the same small bellhousing bolt pattern as the 302 351w and 300.
Old Aug 1, 2005 | 05:17 PM
lisagoud's Avatar
lisagoud
Transmission numbers translated needed
Gang,
I have 1 buddy who is putting together a package utilyzing a 351C. He wants to use one of heavy duty C-4's. I was wondering if anyone had access to what these tranny actually are per their numbers.
1. RF-E0AP-7A105-AA does fit the 351C
2. My heavy duty one is RF-C8AP-7A105-A and I need a bellhousing for that one which would fit a small block.
Old Aug 2, 2005 | 08:25 AM
ronclark's Avatar
ronclark
The c-4 has a removable bell housing Thus you can swap bell housings for which ever you want. I don't think Ford mated a c-4 to the large bell housing bolt patterns unless it was to the 351m so most any you find will bolt up to the cleveland. Ford used the c-6 or FMX for that for their larger displacement engines. If your buddy wants to go heavy duty then a small bolt pattern c-6 would be his best bet. Ford mated the c-6 to 429s and 460s so they can take all the torque and HP you want to throw at them although they were not as efficient as the c-4
Old Aug 2, 2005 | 11:39 AM
lisagoud's Avatar
lisagoud
I'll have to tqake a picture of the bell housing tranny m,asting service...it is different than any other C4 tranny I've seen (I don't know anything about an FMX).
Old Aug 2, 2005 | 12:10 PM
ronclark's Avatar
ronclark
What does the trans pan look like and how many bolts?
Blackfoot Big Block
13
Dec 8, 2009 09:27 PM
460/5
23
Nov 18, 2009 04:49 PM
pcmenten
20
Aug 8, 2007 06:08 PM
ford79man91
Jun 21, 2007 09:41 AM
stats2me
Nov 4, 2005 08:26 AM
