Door Removal Advice
Old Mar 4, 2018 | 09:17 AM
acl9865's Avatar
acl9865
Originally Posted by petemcl
This works well also. Impact screwdriver Home Depot carries them also.
Haha that's exactly what I have. Guess I'll just hit it harder and longer, skip the gym today.
Old Mar 4, 2018 | 10:44 AM
petemcl's Avatar
petemcl
That worked on some of the bolts but not all. I think that every truck is different based upon where it was built and used. You might try a little heat on the stubborn ones. Ideally from the back side where the corrosion lives. Just don't get the hinge cherry red on you might embrittle it.
I replaced those phillips head bolts with allen head bolts and used anti-sieze compound. I'm glad that I did as I have had the doors off several times and that makes it easier. I couldn't find Torx head bolts in that size or I would have used them as they are less likely than allen head to strip out.
GoldCo
22
Aug 4, 2019 05:49 AM
oldracerjones
Jul 23, 2019 02:07 PM
g84t8f1
Mar 31, 2008 07:39 PM
sancochojoe
Feb 1, 2004 10:11 AM
johnarahill
1966 - 1977 Early Broncos
Dec 10, 2003 09:13 AM
