1966 - 1977 Early Broncos
Door Hinge Replacement
Old Dec 1, 2003 | 08:43 PM
johnarahill's Avatar
johnarahill
I have an early Bronco with two of the hinge bolts broken off in the front door post. Is there a way I can get the plate out of the front door post?
Old Dec 8, 2003 | 11:19 AM
jlong1974's Avatar
jlong1974
If you can get at the broken bolt, use vise grips and some heat to try and remove the bolt. Melt a little wax on the bolt as you heat it. It should back out. If that won't work, or the bolt broken off flush with the plate, just drill out the old bolt. Then clean out the holes with a tap. You shouldn't need to remove the plate from the jamb. You can place a door bolt in one of the other good holes and tighten it so the plate doesn't move around while you are working on it.
James, '70 sport 351w
Old Dec 10, 2003 | 09:13 AM
chipper's Avatar
chipper
You could try welding a nut on the end of the bolt, if there is enough of the bolt sticking out. The heat from the welding will help in loosening the bolt.
alchemist1
May 6, 2014 02:30 PM
jdpolecat
Jan 13, 2014 10:11 AM
Canty
Dec 17, 2012 08:47 AM
Itch71
Mar 10, 2008 09:44 AM
blatherskite
Jan 10, 2003 12:12 PM
