7.3l diesel exhaust pipe
You need to educate yourself on diesel basics, and specifics of the 7.3L, before you go modifying things you clearly don't understand.
Diesels do not have oxygen sensors ( Well, some very new ones might, as part of the emissions controls; but certainly not a 7.3)
Most 7.3L's never had "catalysts". IF yours does, you can remove it with no negative side effects.
While some will disagree, most agree that 4" is the biggest exhaust that most 7.3L's need. ( except for very high power custom builds) All a 5" exhaust will get you is more noise, and more aggravation trying to make it fit in places where a smaller pipe was meant to go.
I went with the 5 inch over the 4 purely for the difference in sound. It was a bear to make fit right and is very tight. It will also require some finesse if you have a gooseneck hitch. Mine was rubbing on the hitch and it took some creativity to make fit. If you want more flow but not as much sound, stick with the 4 in. The 5 inch is loud
"Most 7.3L's never had "catalysts"."
__________________________________________________ ______________________
The only 7.3's that were "catless" were the '99.5 through the end run of 7.3's with an auto trans. Earlier than that and all manual transmission trucks came with a CAT. From the factory at least.
1.) My '00 is a manual trans, and it did not come with a cat from the factory. The passenger valve cover list, near the bottom, all the emissions "systems", the vehicle had from the factory. IF it had a cat, it would be listed on the sticker. Mine doesn't.
2.) Also, no OBS 7.3L had a "catalyst". They MAY have had a particulate filter/trap. BUT, they are inert. As they have ZERO PGM content ( platinum group metals), they are NOT, by definition "catalysts", as they have no means of initiating a catalytic chemical reaction.
Even the '99 up, and including 6.0L's, barely qualify as "catalysts" as most have only trace amounts of PGM. It was only in 2008 (6.4L), when the emissions laws changed for light duty diesels, that diesel "cats" and DPF's start to have actual PGM content and catalytic functionality. Same for GM and Dodge. In the scrap world, pre-2008 diesel "cats" are called "junk diesels", and are worth $0-$10 Dodge Cummins are a slight exception, as they introduced their '08+ DPF/CAT system in mid 2007, so 2007.5+ are good for Dodge.
I spent $86.87 on a muffler delete pipe on a stock exhaust thinking it would reduce EBP and show some noticeable difference in turbo performance.
Nothing like throwing $ down the exhaust pipe!
All I got was a louder truck and an excuse for any cop that wants to be an @#$%^&* to pull me over. Not sure how or if they will write a ticket though since I am usually out of state and the home state/county has no inspection requirement.
Plus it's only objectionably loud if you are really getting on it.
Lesson learned about mufflers and power gains. DDT
