Sponsored by: Real Truck
Error Codes and Transmission Problems
Old Feb 18, 2018 | 05:57 PM
colt1126's Avatar
colt1126
So the other day my 99 7.3's automatic transmission quit on me. I was pulling off my road onto the highway not gunning it or anything just normally driving. As I was going into second i felt the truck lunge a little then all moving power was lost. I could push the gas and the rpms would move but the truck wouldn't. 4x4 H and L or Overdrive didn't work as do none of the other gears. Today i checked for any codes and it gave me these codes. Most of which were from when i redid my turbo but there was a couple that I think could quite possibly be linked to the transmission. I checked the codes then cleared them started the truck then checked them again, i the pictures are from both trials. The truck will be going to a shop later this week if I can't figure it out so any help would be appreciated. The first two picture were from the first trial and the last two were from the second trial.
Old Feb 18, 2018 | 06:47 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
Will the truck roll when it is in park? If not, the problem is inside the transmission. If it does roll in park the problem is inside the transfer case. None of those codes have any transmission information.
Old Feb 18, 2018 | 07:30 PM
colt1126's Avatar
colt1126
I also did a compression test on the transmission here is what i came up with
Old Feb 18, 2018 | 09:16 PM
Mark Kovalsky
You should see if it will roll in park.
Old Feb 19, 2018 | 05:32 PM
colt1126's Avatar
colt1126
Quick Update on the truck checked to see if it would roll with it in park and it didn't budge. Just moved a little but didn't roll the tires or anything. Judging by that I'm assuming that it is the transmission.
Old Feb 19, 2018 | 08:50 PM
Mark Kovalsky
Something inside the transmission broke.
Old Feb 20, 2018 | 07:49 PM
colt1126's Avatar
colt1126
Thanks for all your help the truck will be going to a shop sometime this week but i feel a lot better knowing that the problem is the transmission
ford 55
Jun 20, 2012 11:13 AM
duncannon6
Bronco II
Oct 30, 2006 01:23 PM
