Wheel well liners
Old Feb 18, 2018 | 08:50 AM
RGPolo's Avatar
RGPolo
Wheel well liners
Building a F350, scsb $325 for wheel well liners. Worth it??
Old Feb 18, 2018 | 09:09 AM
jimzpsd's Avatar
jimzpsd
If your doing all four, then yes.
Typical price for the rears (only), but you have to install them, pretty simple for most. When I ordered my truck I regret not getting these then, just one less thing to do.
https://www.ebay.com/itm/17-thru-18-...-/172367517871
Old Feb 18, 2018 | 09:15 AM
System's Avatar
System
Prolocutor
The fronts are kind of redundant because the truck already comes with felt type mesh liners up there. While many think this is Ford cheaping out, it's actually done for a reason and likely costs the same as plastic. The stock fabric front liners are sound deadening in the cab where as the plastic make noise when hit with road debris. Many luxury brands use them at all 4 corners to eliminate the noise from rock and ice strikes. So, if you live in an area where there is a lot of mud (on a dirt road for example), the plastic fronts are a good addition as they are easier to clean. However, if you never see mud or off road, I would just get the rears and leave the included fabric fronts to do their thing.
Old Feb 18, 2018 | 09:19 AM
morgan1965's Avatar
morgan1965
Bought my truck off lot without liners. Bought all 4 for $270 from Fairway Ford on eBay. Super easy install. Would do it again.
Old Feb 18, 2018 | 09:27 AM
h20camper's Avatar
h20camper
Yes, I think they are worth having. Clean-up is a breeze. And you probably won't be actually paying the full MSRP of $325 as I assume you're negotiating a discount.
Old Feb 18, 2018 | 10:32 AM
mikemorales's Avatar
mikemorales
Buy it without them. Then spend 125 of the oem rears. The front comes with the felt material like stated earlier. Very easy to install. That’s just my opinion.
Old Feb 18, 2018 | 08:36 PM
First Dually's Avatar
First Dually
What wheel-well-liners are available for a F-450?
It came with rear (standard?) that cover the outer half of the dually wheel well and fronts (optional).
cfpinz
Oct 24, 2019 04:48 PM
Joe308
Sep 12, 2018 03:18 PM
Tawn
Mar 1, 2016 06:20 PM
Robbgt
2009 - 2014 F150
Apr 22, 2013 06:46 AM
maistroyoda
6.7L Power Stroke Diesel
16
Apr 26, 2011 11:00 PM
