Help..EZ Oil drain valve?
I prefer FUMOTO brand. I could not find a clear listing from EZ.
https://www.fumotooildrainvalve.com/...modelId=457437
https://www.ebay.com/itm/Fumoto-F106...9ZVVir&vxp=mtr
As above the part numbers are the same. 106. The 90 degree adapter is helpful to drain directly into empty gallons jugs with a short piece of clear tubing. The EZ is slightly superior to the Fumoto due to it's gasket type and rubber coated turn handle. Both are a great way to change oil though. I've had them on every vehicle I've owned for years. Amazon has both at the best prices last time I checked.
If you don't want to wait until your next oil change to swap in the valve, you tape the end of your shop vac hose to your dipstick tube and turn it on. The suction will allow you to pull the drain plug and install the valve without loosing any oil... Personally, I'd just wait until the next oil change though.
Not the dipstick tube though, the oil fill tube. It doesn't have to be airtight or anything.
Even if you are just changing the oil and you don't use the valve, this method allows you to:
Turn the vac on
remove drain plug
position drain pan
turn vac off
Oil will drain w/o making a huge mess.
When the oil drains out I just installed the valve. Going forward, I slip on a piece of clear tubing, open the valve, and done. No need for the vac again.
