turn signals
Old Feb 17, 2018 | 10:40 PM
mrf-100's Avatar
mrf-100
turn signals
hi members is there a thread on getting turn signals to work mine are all wired in but not blinking and when a test light is used the test light is dim and not blinking either from under the dash at the wiring connecter im using a gm column any suggestions ?
Old Feb 18, 2018 | 12:17 AM
mrf-100's Avatar
mrf-100
im thinking bad flasher , hopefully or bad ground
Old Feb 18, 2018 | 04:25 AM
1949f1's Avatar
1949f1
Sounds like a bad ground. You can never have enough of good grounds and make sure that the grounds are to bare metal and no paint between the connections.
Old Feb 18, 2018 | 07:23 AM
EffieTrucker's Avatar
EffieTrucker
Phantom of the Phorum
Are you using LED lights? If so, are you using a flasher for LED lights?
Old Feb 18, 2018 | 02:06 PM
petemcl's Avatar
petemcl
What year/model of truck? ET is right about the electronic flasher IF you are using LEDs. Otherwise I agree about checking your light grounds. Don't forget the flasher ground which may be the metal can bracket on some non-electronic flashers.
Old Feb 18, 2018 | 03:03 PM
mrf-100's Avatar
mrf-100
no not leds
Old Feb 18, 2018 | 03:04 PM
mrf-100's Avatar
mrf-100
its a 56 f100
Old Feb 18, 2018 | 06:31 PM
mrf-100's Avatar
mrf-100
well while testing things i was checking power at the steering wheel connections and unless i have the test light on the right side connector it wont flash at all the left side wont no matter what i do ????
Old Feb 20, 2018 | 09:37 PM
mrf-100's Avatar
mrf-100
i got it figured out alls working well
Old Feb 20, 2018 | 10:22 PM
49 Merc P/U's Avatar
49 Merc P/U
If you are using the older style flasher they require a certain amount of current flow to heat up the by-metal spring to make it flash. Your test light does not draw enough current to make it work. regards Bruce
F350dog
Dec 2, 2015 05:07 PM
irlfan360
17
Jun 3, 2015 01:18 PM
cwatson1982
Jul 12, 2012 01:31 AM
Tony238
13
Apr 24, 2007 08:28 PM
sully_1
Nov 14, 2001 12:00 AM
