Transmission troubleshooting question
Old Feb 17, 2018 | 07:17 AM
Doug O's Avatar
Doug O
Hello,
Am trying to troubleshoot my 1960 Styleside F100 transmission (3 speed) to get parts on hand before taking it apart. When I drive the truck, there is a high probability that when I shift from 1st into 2d, as soo as I release the clutch, the transmission pops out of gear. When I go from 1st to 3rd gear, and then back to 2d and release the clutch, I have a 50% chance at staying in gear. This happens regardless of whether driving for 5 minutes or 1 hour.
I have seen other posts that make me think the issue is with the synchronizer and maybe the Snap Rings (C2AZ-710-B) or the Synchro shoes (C3AZ-7A044-C) are worn out. I know those parts are available on the web. I just want to make an informed shot at having all the parts and gaskets on hand so when we take it apart, I replace what is worn or broken and don't have to scramble finding parts. Any advice on what we should replace or look for when we open her up?
Any advice is welcome.
Thanks. Doug
Old Feb 18, 2018 | 11:12 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by Doug O
Hello,
Am trying to troubleshoot my 1960 F100 transmission (3 speed) to get parts on hand before taking it apart. When I drive the truck, there is a high probability that when I shift from 1st into 2d, as soon as I release the clutch, the transmission pops out of gear. When I go from 1st to 3rd gear, and then back to 2d and release the clutch, I have a 50% chance at staying in gear. This happens regardless of whether driving for 5 minutes or 1 hour.
I have seen other posts that make me think the issue is with the synchronizer and maybe theSnap Rings (C2AZ-7109-B) or the Synchro shoes (C3AZ-7A044-C) are worn out.
The snap rings and shoes may be worn, but the usual cause for popping out of gear are worn 2nd/3rd syncro brass blocker rings ((2) C3AZ-7107-C).
You will also need a gasket set, small parts kit, front and rear seals.
Pic: 7124 = syncro, 7109 = snap rings, 7A044 = shoes, 7107 = brass blocker rings.
Old Feb 20, 2018 | 09:09 PM
Doug O's Avatar
Doug O
Thanks Bill. You just saved me hours of troubleshooting. I will start calling around tomorrow for the parts and kits. Will let you know the outcome this spring!
Doug
Eagle299
Oct 9, 2014 11:06 PM
SoFla64
Jun 30, 2014 12:49 PM
Elvis40
May 31, 2010 04:16 PM
dspeer75
Feb 28, 2009 08:41 PM
datamover
Mar 16, 2007 04:07 PM
