Seafoam
Old Feb 16, 2018 | 05:04 PM
Mudstare's Avatar
Mudstare
Seafoam
Has any of you guys ever put seafoam in your oil to clean the vct system out?
Old Feb 16, 2018 | 06:51 PM
meborder's Avatar
meborder
I have. Did no harm, but didn't solve the problem I was hoping to solve.
Seafoam is good stuff. I've used it several times in the crankcase. Generally speaking, if something is stuck due to varnish but up, the seafoam will clean it in one treatment.
Of course, it can't fix a broken part.
Old Feb 17, 2018 | 01:14 PM
640 CI Aluminum FORD's Avatar
I just ran two can's of Seafoam through my F-150 5.0L. One can went in the gas tank and another in the crankcase. Wasn't having any particular issue, I had just been researching Seafoam and it's uses and decided to give it a go. Seafoam is the real deal, there's videos on youtube proving that it does in fact break up carbon buildup within the engine itself which is never a bad thing.
Word of advice though, if you run it through your crankcase, I would do it within 150 miles or so of your next oil change. Don't want that excess carbon buildup circulating through your engine for to long.
Old Feb 17, 2018 | 01:24 PM
rbentnail's Avatar
rbentnail
Crankcase no, fuel tank yes. It's good stuff and just like StarTron, etc. I see no harm adding some to fuel once in a while particularly on a long trip when I know it won't be diluted much. For the crankcase I wait until it's time for an oil change and, starting with a cold engine, dump in 1 1/2 qt (I use 1 qt for 5 qt capacity) of varsol and run until warm and change it. Varsol is an industrial solvent but similar stuff can be found at AutoZone, Advance, etc by searching for "engine flush", just follow the directions on the bottle. If it would make you feel better, b/c some folks are so freakin' **** about "getting every single minuscule drop" out: change oil, run for a day or two and change oil again. I do not do this, never have.
Old Feb 25, 2018 | 09:23 PM
Warsaw214's Avatar
Warsaw214
I buy it by the gallon... for 20yrs I've used Seafoam in all my small engine equipment,, boat, cars, etc. However, I have never run it in the crankcase, as I use Mobile One and Royal Purple that prevents build up. I have put 150,000+ on vehicles several times with out any engine issues beyond regular maintenance. If you use clean oil and see noteworthy results please post results
Old Feb 26, 2018 | 09:19 AM
rbentnail's Avatar
rbentnail
I used Valvoline in an '01 XLT for 210,000 miles and it was still running fine with no noise when I sold it. Other than normal maintenance items- brakes and such- everything on that truck was still factory: alternator, water pump, everything. Even the door switches. Amazing vehicle!
So based on the above I also used Valvoline in a '10 for 45,000 miles and anticipated going much, much longer but an old lady yakking on the phone blew a stop sign and T-boned me at 60 mph. Destroyed it. I promptly bought another F-150 based on that crash, making sure my '13 has the same airbag setup. She hit me down low, right at the driver's door and I never touched a thing. I have no doubt the seat back and headliner airbags saved me from severe brain damage or worse.
I have always highly recommended oil sample analyses too. I use Blackstone Labs, they've always done good by me for cars, trucks and bikes. -> https://www.blackstone-labs.com/
Last edited by rbentnail; Feb 26, 2018 at 09:20 AM. Reason: mah spelin sux, knead moor cawfey.
Old Feb 27, 2018 | 08:21 PM
jdunk54nl's Avatar
jdunk54nl
Depending on your engine it won't hurt anything. I use it in my polaris rzr, ninja, kia sorento (non turbo) and most vehicles before that. It has helped clean up rough idle in those vehicles.
I will not use it in my f150 3.5l ecoboost.
Large carbon chunks can break off using sea foam and then be sent through the turbo destroying them. It can also overheat the turbos as it burns hotter.
There is other stuff available for the turbo engines like CRC GDI intake cleaner which supposedly dissolves the carbon instead of breaking it off.
vasten
32
Feb 22, 2025 11:36 PM
blk450er
Sep 14, 2015 11:05 PM
62-f100
Jan 27, 2009 10:15 AM
PW01
Oil & Lubrication
Jan 17, 2006 09:44 PM
BJWinter
1997 - 2003 F150
Jan 15, 2005 11:54 AM
