DEF Code P21B0
Old Aug 19, 2021 | 11:38 AM
droptoppop's Avatar
droptoppop
5th Gear
I did fill it up the other day and yesterday it started showing the system as full with no code. I’m curious as well about non OEM replacement for the heater assembly.
Old Aug 20, 2021 | 09:12 AM
The Bone's Avatar
The Bone
I wouldn't go cheap on this part. Its not hard to do but risk doing it over and over pain in the butt. I got the OEM from a dealer for $300.
Old Aug 20, 2021 | 09:50 AM
Tony Kas's Avatar
Tony Kas
As The Bone pointed out, the risk of doing it over and over is the real concern when determining which part to use as a replacement. The cost difference between OEM and aftermarket is only a couple hundred dollars. The fact that so many failures are reported for the OEM product is what is pushing me towards using the aftermarket product. If I knew that the OEM product had undergone improvements since the factory installation, then I would no doubt use it. Without that info, I can only assume that is is identical to the original and will again fail in a fairly short amount of time.
Old Aug 20, 2021 | 10:09 AM
bobcat67's Avatar
bobcat67
Replaced mine a couple weeks ago with an aftermarket unit, wire points and connections seemed better than OEM unit I took out, works fine too, ran it low then topped off. Got mine off rock auto, which also sells the BOSCH branded OEM unit, no point in paying extra for the same junk. I used the cheapest one I could find, easy job, just ensure cleanliness. Even if I do it 2x I’m money ahead on dealer cost of the part.
Old Aug 20, 2021 | 02:12 PM
Tony Kas's Avatar
Tony Kas
The cheapest one at Rock Auto has a lifetime warranty. I like the strategy of avoiding the Bosch version. Thanks bobcat67 for reminding me of RockAuto. Does have a slightly higher cost than Amazon or eBay, but obtaining through a reputable source and knowing the lifetime warranty is likely able to be supported provides added value.
Old Aug 20, 2021 | 05:11 PM
bobcat67's Avatar
bobcat67
I’m a fan of Rock Auto, sure a person may be able to find a part cheaper on Amazon or EBay, but rock auto will most likely be there for a while, and any issue I’ve ever had had been resolved in a timely manner and professionally. Recently bought a fancy set of drilled and slotted rotors and fancy brake pads, they accidentally sent 2wd rotors, which sucks, but sent me return shipping labels and refunded my money quickly. Ended up being able to turn my stock rotors cause they were in great, almost new shape, pads were shot though. Anyway long story short, good warranty, good price, good service is a win-win in my book.
Old Aug 21, 2021 | 08:49 AM
The Bone's Avatar
The Bone
I don't use Amazon for anything. I will spend more money just to not use them. I like to buy from people in my town. Jeff has way to much money.
Old Aug 22, 2021 | 07:30 AM
Overkill2's Avatar
Overkill2
I second Rock Auto too. Bought many parts for different vehicles too. I've also ordered from Villagefordparts.com. But no filters from neither. I used to order from Amazon for oil and fuel filters but since I had been hearing about the fakes, I stopped. Bought some MC oil filters from Wal-Mart for my last few.
Old Sep 6, 2021 | 10:53 AM
sbeamer's Avatar
sbeamer
How much DEF typically used per 1000 miles ?
Old Sep 6, 2021 | 01:09 PM
Overkill2's Avatar
Overkill2
It depends on how you use your truck and the gear ratio. Mine has the 3.55s. I get at least 7k miles per tank. Probably more like 7.5k miles. But mine doesn't pull anything.
azpat
6.7L Power Stroke Diesel
Jul 12, 2022 08:18 PM
coolemoff1
Feb 21, 2018 06:58 PM
Brian429
2004 - 2008 F150
Mar 17, 2013 04:46 PM
jennkent5454
1997 - 2003 F150
Nov 20, 2009 12:53 AM
murphf-150
Nov 26, 2006 10:54 AM
