Why can't I order a 3.55 axle on my new 2018 F350 4x4 crew cab pickup with 18" wheels, without adding on the heavy duty front suspension package? I was told the ride is stiffer and it raises the front end up. I just pull a 5th wheel trailer; I do not want to put on a snow plow or anything on the front. It comes standard with the 3.31, but I was told the 3.55 would be better in our area and for the amount of time we pull a trailer.
Just went through this. I ordered last week. I went heavy service springs...was cheapest way and hoping to find the regular springs for cheap from someone that replaced with lift.
For 3.55 you need:
Heaven service springs
Camper package
Plow package
Or 20” wheels
Like i said my way was the least money and will see how bad they feel...but I’m coming from a front leaf (04 superduty) so might not be so bad.
Reason: Can’t spell
If you get the heavy front springs for the 3.55 you could probably find the standard springs for very little from someone who lifted a truck.
Even if you bought a new pair of springs at the parts counter and paid to have them swapped in, it would probably still be way cheaper than the 20" option.
Why can't I order a 3.55 axle on my new 2018 F350 4x4 crew cab pickup with 18" wheels...
I'd also suggest considering the inexpensive camper package option ($160 MSRP) as a path towards being able to order the 3.55 axle. The F350 with 18" wheels already includes the five-leaf rear springs, so the CP only adds a rear sway bar and -- at most on the 4x4 -- "one-up" front springs.
I suspect you wouldn't notice the marginally stiffer front springs, especially with the heavy diesel engine.
Go camper package. I notice the lack of sway bar on my new one.
Im also in the "I tow heavy with 3.31s and it's fine" group but I wish I had the 3,55s.
I have the plow springs on my 250. I don't think they're real plow springs. They ride OK. Especially since they seem to be nicely matched to the rear springs. (maybe not on a 350) And they tow well. No porpoising. I'd give the HD, Camper, or Plow springs a fair chance. If you don't like them, it's a quick easy change.
Some of the 350 plow guys are running f550 springs.
I ordered the camper package, specifically to get the 3.55 ratio. I have plenty of front rake still. I don't think I'll ever have a truck without a rear sway bar.
