Sponsored by: Real Truck
suspension package ?
Old Feb 27, 2004 | 07:41 AM
dlkennedy's Avatar
dlkennedy
Question suspension package ?
Could someone tell why the Snow Plow Package is $70 and the Heavey Service Suspension Package is $125. What is the difference? I assume they are different springs but why such a big difference in price.
Old Feb 27, 2004 | 09:53 AM
sportscar's Avatar
sportscar
Are we talking SuperDuty? Judging by the descriptions on Kelly Blue Book site, www.kbb.com, the Heavy package seems to "add " extra helper springs. KBB also states "may degrade ride quality".
So I think it takes the Snow Plow prep and adds helper springs. The F250/350 brochures says the the package id for trucks with permantly installed aftermarket front end equipment.
Old Feb 27, 2004 | 10:22 AM
twoballsleft's Avatar
twoballsleft
The snow plow pkg will give you the "Highest Front GAWR Springs(5200lbs). All others state "Heavy Service Front Springs". The door sticker will state 5200lbs if you get the Snow Plow or camper pkg... The snow plow Pkg availability depends on model..I.E if diesel, only Reg. cab and SC/SB allowed. The Heavy Service Suspension may be the substitute for the 5200lb front spring on all others...not quite sure.
The reason I say this is again all the rest state "heavy service" and I got the stabelizer pkg and the sticker on the truck was 4940lbs not 5200.(something like that....the truck is gone now). I am in the same process and do not want to mess this up again..
Check the door stickers vs pkgs on the trucks on the lot. You want the 5200lb front springs for sure if you get a PSD...sits higher and in my opinion rides better.
I just found a glitch on the KBB site...If I build a F350 SC/SB PSD SRW and add the Off Road Pkg, it makes me choose a 4.10 or 4.30 rear and throws the whole thing off. PSD SRW is only avail with a 3.73. Any one else see this problem?
Old Feb 27, 2004 | 10:41 AM
dlkennedy's Avatar
dlkennedy
I'm probably going to order a f350 CC SB PSD tomorrow. I would like the 5200 lbs springs and a steering stabilizer, but I'm not sure what package to order. If I understand it correctly, I can't order the snow plow package with a CC.
Old Feb 27, 2004 | 10:51 AM
twoballsleft
I believe you are correct....with the CC/PSD, Ford wont allow it....try building it on Ford's site. This is why the Heavy Service Suspension Pkg. is offered....I think. The source book does show 5200lbs for the HSS Pkg. on the CC with PSD. Again, check the door sticker against the options on the window sticker.....take your time and get it right.
Old Feb 27, 2004 | 01:33 PM
wlihntr's Avatar
wlihntr
i have the camper package on my truck, which includes the rear helper springs, the front steering stabilizer, and heavy service front springs. i just went to the garage and looked on the door sticker" front gvw 5200 lbs" so if you get the camper package on the cc you should be good.
Old Feb 27, 2004 | 01:40 PM
twoballsleft
Hey wlihntr....out of couriosity, do you have a stearing damper too? I would think that would be part of a camper pkg but it dosn't list it?
Old Feb 27, 2004 | 01:52 PM
dlkennedy's Avatar
dlkennedy
A steering dampener probably was part of the camper package in '01, not sure about now.
Old Feb 27, 2004 | 02:39 PM
wlihntr's Avatar
wlihntr
yes, steering stabilizer/damper same thing(shock on the steering linkage)
Old Feb 27, 2004 | 06:38 PM
sinjin's Avatar
sinjin
Could we clarify? I thought this "steering damper" came with the FX4 package only. I only recall the rear sway bar as part of the "camper package". And so the camper package has a greater number of leaves in the pack, is that how it works?
Old Feb 27, 2004 | 06:53 PM
Yeti's Avatar
Yeti
I got the steering damper with the plow package on my o1
Old Feb 27, 2004 | 07:00 PM
twoballsleft
Suspension Pkg., Heavy Service
(N/A w/Snow Plow Pkg.-86M, Camper Pkg.-532, Stabilizer Pkg.-63B or GAWR Pkg.-682) (Recommended Only on Vehicles Which Will Permanently Utilize H.D. Aftermarket Equipment) Includes Steering Damper & Heavy Service Front Springs.
Stabilizer Bar Pkg. • Models w/SRW
(N/A Models w/DRW) (N/A w/Camper Pkg.-532, Snow Plow Pkg.-86M or Suspension Pkg.-674) Includes Heavy Service Front Springs & Rear Stabilizer Bar.
Snow Plow Pkg. • 4WD Models w/o Trailer Tow Pkg. Delete-M53
(N/A 2WD Models) (N/A w/Suspension Pkg.-674, GAWR Pkg.-682, Stabilizer Pkg.-63B or Harley-Davidson Pkg.-17H) (N/A w/99P 6.0L Diesel Engine on Models w/SRW & 8' Bed or Models w/DRW) (Restrictions May Apply) Includes 6000-lb. Cap. Front Springs & Steering Damper.
Off-Road Pkg., FX4 • 4WD Models
(N/A 2WD Models) (N/A w/Harley-Davidson Pkg.-17H) (Req's Axle-XD* or XF*) (Req's Tires-T4B or T4R on Models w/SRW) (Req's Tires-T3N or T3R on Models w/DRW) Includes FX4 Badging, Skid Plates, Steering Damper & Unique F&R Shock Absorbers.
GAWR Pkg., Max. Front (LPO)
(N/A w/Snow Plow Pkg.-86M or Suspension Pkg.-674) (Req's Ford Approval on 2WD Models) (Restrictions May Apply) (May Result in a Deterioration of Ride Quality) Includes Steering Damper & Max. GAWR & Front Springs.
Camper Pkg. • Models w/o Trailer Tow Pkg. Delete-M53
(N/A w/Suspension Pkg.-674, Stabilizer Pkg.-63B or Pickup Box Delete-66D) Includes Auxiliary Rear Springs, Rear Stabilizer Bar, Heavy Service Front Springs & Slide-In Camper Certification.
Old Feb 27, 2004 | 07:09 PM
sinjin's Avatar
sinjin
Thanks Lefty.
I had never looked into the plow package. So if I want the damper and I'm committed to the camper package I'd have to get the FX4 package. Since the shocks and skid plates are only so so, would the damper be worth the price of of the FX4 package?
Old Feb 27, 2004 | 07:22 PM
Yeti's Avatar
Yeti
Heck no, you can get a better aftermarket damper for $75 bucks.
Old Feb 27, 2004 | 09:06 PM
twoballsleft
No Problem, sinjin......if that's all ya need, by all means yeti's right...buy one off the street.
Even with it all in front of you, it's still pretty confusing. I'm going package hunting tomorrow to figure out what rated springs are on each pkg...I'll post my findings...stand by.
