Sponsored by: Real Truck
Need help with info
Old Feb 14, 2018 | 02:58 PM
2006f350shd's Avatar
2006f350shd
Need help with info
I own a 2006 f350 super duty king ranch the left front tire fell off lug nuts were snapped check the passenger side and three of them were loose had flood Ford fix it because they are the ones that changed all 6 tires on it they are charging me money because they said it is my fault because I was letting the truck sit too long and not using it is the reason why they broke off is this true
Old Feb 14, 2018 | 03:35 PM
ibdagriz's Avatar
ibdagriz
Ask for proof of that happening. PROOF.
Not , "Well we had a guy come thru here once..."
Stupidest thing I ever heard I do believe.
Griz
Old Feb 14, 2018 | 09:23 PM
Lawnpro979's Avatar
Lawnpro979
That’s one of the stupidest things Ive ever herd.....
So under this logic, the street lights would fall over. “ the ones bolted down”
the bridges would collapse....
many autos have sat for years....even decades, and the wheel lugs didnt fall off.....
Good God man! Ive herd everyhting now!!!!!!
Old Feb 15, 2018 | 05:00 AM
Chuck's First Ford's Avatar
Chuck's First Ford
I am a retired mechanic.. that "IS" the dumbest thing I have ever heard...
and baseless...
get the manager or owner involved.
stud's break = over tightened....or someone hit a curb Hard.
loose = some one left them loose.
Old Feb 15, 2018 | 07:09 AM
DogRidesInBack's Avatar
DogRidesInBack
The tires would go completely flat and probably rot away long before studs would break from sitting.
However, most service standards call for retorqueing the nuts after some number of miles. Did you have that done? Frankly, almost no one ever does.
And even then I've never had one snap. Have had a couple instances over the decades where a wheel started vibrating or making noise due to loose nuts. But have never had a catastrophic failure.
Old Feb 15, 2018 | 07:14 AM
Chuck-B's Avatar
Chuck-B
6.7 Weight Loss
Did they also tell you your muffler fan fluid needed to be changed? Back, way back when I just got out of high school I worked for a Lincoln Mercury dealership doing new car prep and menial tasks like rotating tires. When I put this car on the lift and spread the forks to the frame I pushed them too close to the tires. When the car went up on the lift the forks put pressure on the tire. I rotated the tires, torqued the lug nuts and gave the customer his car. 3 days later he was back, clunking in both front tires. Took the hubcaps off and the lugs were loose - the rims & lugs were destroyed as well. Betting this is what happened to you
Old Feb 18, 2018 | 04:01 PM
4XBuilder's Avatar
4XBuilder
Another vote for over torqued lug nuts.
Old Feb 18, 2018 | 08:31 PM
m-chan68's Avatar
m-chan68
As a fully licensed Ford dealer technician since 2000, and wrench turner for nearing thirty years, my vote is for over torqued wheel nuts as well.
erinaldi
20
Nov 2, 2011 04:41 PM
PowerstrokeRyan
20
Oct 28, 2011 11:55 PM
dirtballer
Apr 11, 2009 05:09 PM
Smokin'
29
May 5, 2007 12:19 AM
kawcrasher
Jul 3, 2006 02:36 PM
