BIG shocks thread. ($1000+ each)
Old Feb 14, 2018 | 01:59 PM
0835064's Avatar
0835064
It holds up to towing very well until you go over 1k tongue weight! Def not half ton status, wife has a 2018 f150 and it’s still considerably stiffer and holds weight much better than that. That being said I don’t tow heavy, often enough for the lighter load carrying ability to bother me enough to get airbags just yet.
It is awesome to drive on and esp Offroad!
Old Feb 14, 2018 | 02:18 PM
Tricon's Avatar
Tricon
Oh I know how awesome they ride. I live a couple miles away from Carli.
Deaver says they lower the payload 1,000 lbs. That's 1,500 lbs or so of payload which is definitely 1/2 ton territory. I'm sure it would be fine, but my Toy Hauler is about 1,100 lbs tongue weight, and I bought this truck to tow first, offroad second. I just can't reduce its towing capabilities in good conscience.
Old Feb 14, 2018 | 02:27 PM
legacy91's Avatar
legacy91
How do the mini packs ride?
Old Feb 14, 2018 | 02:41 PM
Tricon's Avatar
Tricon
I've never expereinced them first hand, but I've heard a couple guys say it wasn't worth the $865. Pure Performance has some for $550. I've been holding off because I haven't heard any good reviews yet.
Old Feb 14, 2018 | 02:55 PM
0835064's Avatar
0835064
Oh if I had a big trailer or towed more def not these springs but as is I spend a lot of time off road and the roads of NC are horrible so this works great as for Offroad that’s what this is for.
Old Feb 14, 2018 | 03:00 PM
Tricon's Avatar
Tricon
With ya there! My 3 car garage is packed with KTM's and desert toys. No room for silly cars!
Old Feb 14, 2018 | 04:48 PM
Buliwyf's Avatar
Buliwyf
The only thing I can see the minipack doing, is reducing axle wrap. All it does is replace your block with a stack of springs. So when someone says that it actually helped the ride, I don't see how that's possible.
Old Feb 14, 2018 | 05:40 PM
0835064's Avatar
0835064
Carli told me they would actually make the ride worse on my 350 because of the third leaf.
@tricon nice toys I too rode orange till I sold it to buy my skydiving rig.
Old Feb 14, 2018 | 06:25 PM
honda250xtitan's Avatar
honda250xtitan
Its gotta be a bit better tho right?? three smaller leafs replacing one fat one?? Or should they come out with a small pack for the front half of the wheel travel...like a progressive shock. Super plush in the initial travel, stiffens up as you get to the second half of the bump travel? All i know, my camper package springs ride like a ROCK when i don't have the dump trailer hooked up lol.
On wheel hop note...anyone adding traction bars? I built some for my titan and it was unreal how much they helped. No wheel hop, also helped eliminate the one tire fire.
Old Feb 14, 2018 | 06:28 PM
Tricon's Avatar
Tricon
The pack should help soak up the small freeway type bumps, in theory. You are using the travel, albeit small, in the pack before you start using your main leaf pack. Rather than with a block you are using your main pack right from the get go.
Now if that translates into real world awesomeness...no idea. I couldve sworn someone here got them, but cant remember who. Maybe Joneseer or Kbryant?
Old Feb 14, 2018 | 07:27 PM
CopterPilot's Avatar
CopterPilot
I had the Add-A-Packs on my 2005 F250 and now the Full Progressive leafs on my 2017 F350 so not quite an exact comparison but I can say that the Add a packs smoothed the ride noticeably. No where near the plushness of the full leafs but its a great start. With a good set of shocks I'm sure they can ride pretty well.
They also did not sag near as much as my stock F250 springs when my fifth wheel was hooked up.
Admittedly the X factor here also could be the fully boxed frame.
Old Feb 15, 2018 | 06:21 AM
Buliwyf's Avatar
Buliwyf
That's good news. Thanks.
dpayne7571
May 28, 2019 09:19 AM
Tedorama
Jan 14, 2019 06:18 PM
FirstFord18
Jan 8, 2019 09:14 PM
BCfordman38
Apr 9, 2015 07:25 AM
HarleyFXDL
Mar 2, 2009 11:21 PM
