Engine indentification
Old Feb 13, 2018 | 11:28 AM
Pladsmand's Avatar
Pladsmand
engine nr D20E-6015-ab i ned some document about HP and from which vehicle it came from we have some stupid ruels here in Denmark we have to document everything. I hope some Can help me with somthing i Can print out
Old Feb 13, 2018 | 01:02 PM
HIO Silver's Avatar
HIO Silver
How many valve cover bolts? V8 or inline six cylinder?
Old Feb 13, 2018 | 02:28 PM
Pladsmand's Avatar
Pladsmand
6 bolts and v8
Old Feb 13, 2018 | 05:57 PM
ultraranger's Avatar
ultraranger
Could be a 351W but is likely a 302.
Old Feb 13, 2018 | 11:22 PM
Pladsmand's Avatar
Pladsmand
It is a 302 but from the number D20E-6015-ab some must be able to find out which vehicle it came from and how many hp
Old Feb 14, 2018 | 01:07 AM
mrollings53's Avatar
mrollings53
The first four positions should read D2OE. The O means Fairlane/Torino from what I've found online. What is the date code on the block? You can also check to see if a partial vin was stamped on the back of the block.
Partial VIN locations:
If they want to know how much horsepower it has assemble it then take it to a dyno.
Can your local Ford dealer help with any of this?
Old Feb 14, 2018 | 02:23 AM
RichS2659's Avatar
RichS2659
He is in Denmark so his Ford dealer is of no use as this is an American engine. In Europe, the government controls everything restricting any changes made to vehicles. I was stationed in Germany for 5 years so I know how it is. With a block casting code and date code, the date can be narrowed down for the horsepower of the engine at that time.
Old Feb 14, 2018 | 03:05 AM
Pladsmand's Avatar
Pladsmand
I just had to documet where the engine comes from, how old, how big (cui), and how many hp it factury had the time this engine was built. Here is What i found on the top of the engine 3K115777
Old Feb 14, 2018 | 07:03 AM
ultraranger
A "D2" casting date would be for the model year 1972.
Through '71, Ford rated the engines in gross horsepower. '69-'71 302s were rated at 210 horsepower with 295 lb-ft of torque.
From '72 onward, Ford rated the engines in net horsepower. A '72-'80 302 was rated at 135 hp and 243 lb-ft of torque.
Old Feb 15, 2018 | 12:29 AM
Pladsmand's Avatar
Pladsmand
Can you guide me to where i can find this you wrote så i can print out document
Old Feb 15, 2018 | 06:53 AM
ultraranger
Ford 302 cid (5.0L) Windsor V-8 Specs
71fordkid
Jul 14, 2021 02:18 PM
Jack118711
151
Jul 6, 2019 02:00 PM
breadstick
17
Mar 13, 2012 02:35 PM
1mollyd
Flathead V8 & Flathead 6
Jan 14, 2012 05:09 PM
john fin
Oct 2, 2011 01:54 PM
