Carburetor on 1969 F600
Old 02-11-2018, 07:45 PM
Fordnoober's Avatar
Fordnoober
Fordnoober is offline
hey guys. I’ve been looking and looking all over and I just cannot find for sure which carb will replace the one on my 69 f600 stake truck. Carb tag says auto lite c6tp c 6mc and my vin is f61ccf37040. I saw from another post that I may have a 330 2v ft engine, but when I search for my carb tag I could only find pn 2100,A800 for 289 Cu, 302 Cu, Or 351 Cu. My leave of knowledge is pretty low. Can anyone recommend a carburetor that will fit?
Old 02-11-2018, 09:25 PM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
Carb tag says Auto-Lite C6TF-C - 6MC and my VIN: F61CCF37040
I saw from another post that I have a 330 2V FT engine.
Auto-Lite (1962/72) & Motorcraft (1973/74) 2100 series 2V's were used on myriad 1962/74 Ford/Merc V8's.
But, this is not the original carb for your truck, it was replaced (probably w/a used carb) by a previous owner, as it's application is: 1965/67 F100/350 352.
ID tag number: C6TF-C = Ford part number: C5TZ-9510-N replaced by C9UZ-9510-AA .. 2100 series 2V (Auto-Lite/Motorcraft CA-698)
6MC = Assembled the 3rd week (C) of December (M) 1966 (6).
F61 = F600; C = 330 2V M/D FT engine; C = Oakville Ontario Canada Truck Assembly Plant; F37040 = 1969.
Old 02-11-2018, 10:04 PM
Fordnoober's Avatar
Fordnoober
Auto-Lite 2100 series 2V's were used on myriad 1962/74 Ford/Merc V8's.
But, this is not the original carb for your truck, it was replaced (probably w/a used carb) by a previous owner as it's from a 1965/67 F100/350 352.
Thanks you are awesome.
so I assume this carb will work as a replacement -Part Number2100,A800Venturi Size1.14inch,300CFMManufacturer Part NumberTM-183-HCY
any other suggestions? I was reading about some stroker kits available while on my carb search seems like the engine may be able to handle some more power. It the coming year I hope to dig into this a bit.
Old 02-13-2018, 05:21 PM
JEFFFAFA's Avatar
JEFFFAFA
JEFFFAFA is offline
HMMM. The 1.14 would work but I doubt your 330 will ever see higher RPM under power. Think I'd go with the 1.08 if you can find one.
But I suggest you go to the FE and FT engine board.
Old 02-14-2018, 04:15 PM
matthewq4b's Avatar
matthewq4b
matthewq4b is offline
That is an emmsions carb you don't want that. I tis a 2150 your truck has a 2100.
If you have your Original carb I suggest sending it out to be rebuilt if you do not feel confident doing it yourself.
The 2100 is about the easiest carb in the word to rebuild though and there are lots of tutorials on line on how to do them.
You will not find a properly calibrated reman carb to fit your engine all the part's houses stopped carrying them decades ago.
Your only real option is to get yours rebuilt or buy a new 2300 Holley to drop on it.
Old 02-15-2018, 06:53 AM
Rasputin53's Avatar
Rasputin53
Rasputin53 is offline
2100's are easy to rebuild. Plenty of guides out there about it. Kit is usually ~$15. Get the Ford kit. It will work fine on your motor. Be careful getting the jets out. Big flat blade screwdriver with a piece of cereal box wrapped over the end. Fill up the slot. I'm talking giant screwdriver here.
Make a soda blaster: Homemade Soda Blaster - HomemadeTools.net
Then use your cleaner of choice to get the passages clean. I use Simple Green in a bucket. Leave over night. I also use a large baker tray to work in/on so the little check ball doesn't get lost. Easy-peasy.
scramboleer
03-20-2013 12:29 PM
SCRebel
12-26-2012 10:10 AM
SGT DuckButter
Large Truck
08-09-2012 11:54 AM
z1121jack
11-16-2009 04:56 PM
boggerted
06-02-2009 09:57 PM
Quick Reply: Carburetor on 1969 F600
