Plastic Oil Drain Plug
Old Dec 12, 2020 | 11:19 AM
  #46
cwtex04's Avatar
cwtex04
I had a 2012 F 250 6.7 diesel with the plastic oil pan and drain plug . Never had a leak or any other issue with either one . I think the problem some people have with the plug is over turning it to loosen or tighten it up . It’s basically a quarter turn either way . I wish my 2020 F 450 had it . Easiest oil change I’ve ever done .
Old Dec 12, 2020 | 08:56 PM
  #47
Tennesseepowerstroke's Avatar
Originally Posted by John Mortimer
Hello, i work at Vavoline and we get plenty of fords coming in with the yellow plastic twist plugs. We replace the plug every time but you will be fine to reuse the current plug for a few more times. The hot oil eventually starts to shrink the plastic and sometimes eats away at the plastic over time so you don’t want to reuse it if you notice any leaks.
Welcome to the forum John Mortimer. If I had one of those plastic plugs, I would be looking for a better solution also. I am sure others will be swear by theirs but I am not a fan of plastic oil plugs.
tnfordblue
Escape & Escape Hybrid
Jan 5, 2019 05:37 PM
RedFish_n
6.7L Power Stroke Diesel
Oct 29, 2016 10:01 PM
jonrjen
26
Mar 31, 2014 07:44 AM
OfficerDangle
30
Dec 31, 2005 08:29 AM
