Frustrated
Old Oct 28, 2016 | 10:42 PM
RedFish_n's Avatar
RedFish_n
Frustrated
Decided to change my oil today. The dealer had done all of the oil changes prior. Move truck to yard and crawl under being not sure what to find for a drain plug. Read on this forum about some type of plastic thing. I have a regular drain plug. Go to shed to get ratchet set and start taking drain plug off. Broke nice and easy but started to get harder the more I removed it. Had to use the wrench it with two hands to take the plug off. By this time I am really using some choice words about the dealer. There is no way a drain plug should be this hard to take off. Once off, I notice that the threads are messed up. Take plug to dealer and ask service guy what is wrong here? He says looks like pulled threads. They see that all the time he said. I told him that I never seen that with a drain plug before and I did all the maintenance on my old truck and that they won't see any of my vehicles for maintenance again. It looked to me that it was cross threaded. Well I left the dealer with a new $11 drain plug. Is this something new with drain plugs these days or did the flunky that changed my oil last time do something wrong?
Sent from my iPad using IB AutoGroup
Old Oct 28, 2016 | 11:50 PM
Dakster's Avatar
Dakster
Never had that issue - sounds like it was cross threaded the last time it was put in.
The plastic plug was only on 2011 trucks - I actually liked it better than the traditional one.
Did you get to take an oil bath? That is where my kids learn lot of new 4 letter words. Hasn't happened in a while (thankfully).
Old Oct 29, 2016 | 01:10 AM
94ruck's Avatar
94ruck
My 2015 is simply break loose and spin off by hand. no problems...I have a big catch pan to catch the oil.
Old Oct 29, 2016 | 06:33 AM
RedFish_n's Avatar
RedFish_n
Yea on the oil bath. I have a large pan and it shot right over the top. How hard could it have been to angle it down some when it was designed.
Old Oct 29, 2016 | 06:55 AM
System's Avatar
System
Prolocutor
Milton, do yourself a favor and get an EZDrain valve to put in place of the drain plug. No more thread worries, and better yet, no more mess. Then get the extension nipple and you can drain it right into empty gallon jugs with a small piece of 3/8th inch tube.
https://www.amazon.com/gp/product/B0...=AW1BITT3UOQ37
https://www.amazon.com/gp/product/B0...=ATVPDKIKX0DER
Old Oct 29, 2016 | 07:29 AM
lynnmor's Avatar
lynnmor
Of course it was a flunky, who do you think gets the miserable job of doing oil changes? You really must do everything that you possibly can without the aid of flunkys.
My concern would be that the oil pan threads were damaged as well, and would insist that they provide you with a new one and another new oil plug. If you do keep using the old one, and a problem develops, oversize plugs should be available at a parts store.
Old Oct 29, 2016 | 09:54 AM
HRTKD's Avatar
HRTKD
+1 on the oil drain valve. Best modification ever!
Old Oct 29, 2016 | 10:28 AM
FishOnOne's Avatar
FishOnOne
Probably because the engineer who design the oil pan doesn't change his oil...
Old Oct 29, 2016 | 04:44 PM
Dakster's Avatar
Dakster
I'm sure than engineer is laughing his or her butt off every time they read about someone getting an oil bath.
I need to get an ezdrain or fumoto valve. I got used to not having one since they were not available for the 2011 year trucks so it wasn't on my mind this time used them before and liked them.
Old Oct 29, 2016 | 10:01 PM
joeyou's Avatar
joeyou
Not true....my 2012 has the plastic drain plug (plastic oil pan too).
MG250
6.7L Power Stroke Diesel
37
Dec 29, 2020 09:54 PM
A/Ox4
30
Jul 14, 2019 10:26 AM
JimsRebel
Aug 3, 2017 04:31 PM
littlegreenford
Modular V8 (4.6L, 5.4L)
Dec 14, 2008 11:29 AM
