New 6.7 accessory!
Old Feb 12, 2018 | 05:57 PM
bldfrdblu's Avatar
bldfrdblu
New 6.7 accessory!
So I'm messin' with the 2018 SD build and price for the umteenth time and boom! An operator regeneration control button option! $250. OUR VOICES HAVE BEEN HEARD, by the Mothership! Also new is a "manual shift on the stop" transfercase option.
Now if FORD would make power running boards a stand alone option instead of part of the Ultimate Package I might have to pull the trigger before they change their minds!! 😄
Old Feb 12, 2018 | 06:08 PM
TxHeat's Avatar
TxHeat
What trim level are you building? I thought the manual option was only available on the XL and XLT models.
Faceplant409's Avatar
Faceplant409
  • I’m finalizing order tonight. Whered you find those?
Old Feb 12, 2018 | 06:14 PM
cficare's Avatar
cficare
OCR was a 2017 option on XL and XLT trim levels. Are you saying it's now available across the board?
Old Feb 12, 2018 | 06:52 PM
screwy's Avatar
screwy
you can add it to any model with forscan, or by asking the dealer to turn it on.
Old Feb 12, 2018 | 06:58 PM
bldfrdblu's Avatar
bldfrdblu
I was in both xlt and lariat builds. It was something I'd surely never seen before. I know there have been some threads on this wanted option due to the "ill timing" of regeneration some owners have spoke about. That's why it stood out.
Old Feb 12, 2018 | 07:05 PM
cficare's Avatar
cficare
2018 specs still say only XL & XLT trim levels ...
Old Feb 12, 2018 | 07:09 PM
HRTKD's Avatar
HRTKD
Fake News!! LOL! Sorry, couldn't help myself. Would be cool if true.
Old Feb 12, 2018 | 07:19 PM
bldfrdblu's Avatar
bldfrdblu
i just "rebuilt" a xlt, 6.7 4x4 with all tow options and it's right above the sunroof box.
just sayin'
Boasty's Avatar
Boasty
How do you find the control for the regen if you have it? If I add it by forscan I would need the sync 3 8 inch screen right?
Old Feb 12, 2018 | 07:30 PM
mhoefer's Avatar
mhoefer
No, it doesn't show in the sync screen, it shows on the dash under engine controls above the steering column. Just need Forscan and the added functionality, but then you must regenerate if auto is turned off. I have not seen as yet if auto regen is off (deselected) if it gives you warnings that regen is due? Problem being if someone else were to be driving the truck would they just ignore and plug up and ruin the DPF?
cficare's Avatar
cficare
XL and XLT, yes. Spec sheet indicates not available on Lariat, KR, Plat & Ltd ...same as 2017 model year.
Old Feb 12, 2018 | 07:35 PM
bldfrdblu's Avatar
bldfrdblu
Correctamundo! Built a Lariat and no option-even with Ultimate Package.
Old Feb 13, 2018 | 11:25 AM
Tricon's Avatar
Tricon
Its not even really what you want. You can tell it when to regen, but only once the DPF is at 100%. At that point, I'd rather just keep it on auto. It essentially allows you to delay the regen to a convenient time, once its completely full.
rrgone
2015 - 2020 F150
May 23, 2019 10:06 AM
adrienne2242
2015 - 2020 F150
19
Nov 21, 2017 05:35 PM
OTL_himself
2009 - 2014 F150
26
Apr 27, 2017 06:57 PM
supeRobertduty
Dec 9, 2016 10:30 AM
melisa
Mar 17, 2004 07:45 PM
