How to Repaint Timing Marks?
Old Feb 11, 2018 | 10:01 PM
Tim Hodgson's Avatar
Tim Hodgson
I tried repainting the timing marks when I rebuilt my distributor last year. I cleaned the area very well, then smeared white paint into the mark recesses let it dry then tried lightly painting dark blue paint over the area, trying not to get any blue paint into the mark recesses. And it turned out ...
Horrible!
So do any of you have any tips or tricks to repainting the timing marks so they look like this:
I stole the above image from a post by subford in another thread.
Old Feb 11, 2018 | 10:25 PM
buddy119's Avatar
buddy119
Might try some timing tape.
Old Feb 12, 2018 | 07:54 AM
jas88's Avatar
jas88
You paint white or yellow over the area, then wipe it with a dry cloth while still wet so it just leaves paint in the recessed parts.
Old Feb 12, 2018 | 07:57 AM
Scndsin's Avatar
Scndsin
Clean the marks with a stiff brush & acetone to clean out the engraving.
You can paint however you wish with white paint. (brush, spray)
I like to put a dab on my finger & wipe it across the engraving, since that forces the paint in the groves & removes excess at the same time.
You can wipe off excess then, or wait till dry.
You can do the same, less long lasting, with chalk.
Works for me, your results may vary.
Old Feb 12, 2018 | 02:09 PM
willowbilly3's Avatar
willowbilly3
I always use white out or more often, welders chalk. All I have to mark is tdc because I use a dial-back timing light.
Old Feb 12, 2018 | 03:00 PM
95fiveoh's Avatar
95fiveoh
I used an ultra fine silver sharpie. Only color the mark you need.
Old Feb 12, 2018 | 03:44 PM
Tim Hodgson
Thanks for all the suggestions so far. I think I will repaint the harmonic damper ring, and scrape a little paint from the engraved recesses and try 95fiveoh's suggestion with one or more of these:
https://www.ebay.com/itm/Fine-Sharpi....c100506.m3226
Old Feb 12, 2018 | 06:09 PM
Diesel_Brad's Avatar
Diesel_Brad
Winner Winner chicken dinner
Old Feb 12, 2018 | 08:48 PM
westcoasting's Avatar
westcoasting
Use a white paint pen, my local auto parts sells them and also the hobby shop sells them. Basically a felt pen that uses paint.
Old Feb 12, 2018 | 09:57 PM
Eric Fullerton's Avatar
Eric Fullerton
Printable timing tape https://www.blocklayer.com/timing-tapeeng.aspx
DBGrif91
May 4, 2011 01:32 PM
Field Muzzy 125
2004 - 2008 F150
21
Nov 23, 2007 06:37 PM
mike6.0
Appearance & Dress-Up
Nov 27, 2006 10:45 PM
fordraceing_man
Oct 4, 2005 11:24 AM
rka159
Aug 14, 2003 08:45 AM
