How did you repaint timing marks?
Since I'm having difficulty deciphering a code 213 on my beast, I thought it would be wise to check to see if the computer is actually advancing the timing as it should be. I have a timing light but need to repaint the timing marks before I can check.
Just wondering how you did it and what type of paint you used. I've heard of some guys using white out and getting good results- if that worked for anybody here I'd like to hear about it.
I usually use one of those white or yellow paint pens, and on the balancer I don't paint the mark itself - I paint around the area (cleaning and degreasing first), and then use a scribe to re-make the mark within the painted area. This makes the original mark both highly visible and accurate as well. Painting a 1/8" or wider line for your mark can add a couple of degrees of slop to the setting.
'78F250351m
20
07-06-2011 06:44 AM
MSC
04-25-2004 03:13 PM
