FORScan spreadsheet
Old Feb 10, 2018 | 08:42 AM
2016.150XLT.Tampa's Avatar
2016.150XLT.Tampa
FORScan spreadsheet
Does anyone have a spreadsheet for a 2016 F150 XLT? Looking to make some small adjustments like auto S/S, enable bedlights, disable seatbelt alarm, disable door alarm, etc.
Old Feb 10, 2018 | 11:22 AM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
https://docs.google.com/spreadsheets...5730/htmlview#
Old Feb 10, 2018 | 12:03 PM
2016.150XLT.Tampa
Bed lights
Thanks. I don’t see the bedlights on this list. Do you have those numbers by chance?
Old Feb 10, 2018 | 12:08 PM
Bullitt390's Avatar
Bullitt390
That is the complete list of all modules that can be modified.
BCM 726-57-01 is a Bedlamp configuration that I see on a quick scan
Old Feb 11, 2018 | 08:49 AM
oldakerw's Avatar
oldakerw
Spreadsheet Thank You & Question
Any idea how to convert HTML to an actual spreadsheet?
Do you also have spreadsheet referenced as "** see separate spreadsheet tab below called "Add NAV to 2015s" **"?
Thank you again.
Old Feb 11, 2018 | 09:21 AM
storage_man's Avatar
storage_man
Thank you again.
If you click on the "File" drop down menu, it will allow you to download the sheet in various formats.
Old Feb 17, 2019 | 11:14 AM
mxracer78's Avatar
mxracer78
Thank you again.
"File" doesn't show up in the HTML view of the google doc.
just remove the "htmlview#" at the end of the URL
so instead of using this "https://docs.google.com/spreadsheets/d/1uDSQ1Z5a2Wt8-kjrSiVSlDFGFHnfeuhb3RTMVz95730/htmlview#"
use this*https://docs.google.com/spreadsheets...hb3RTMVz95730/
now file shows up at the top of the page
Old Jun 12, 2019 | 09:22 AM
Royneal32452's Avatar
Royneal32452
Printing spreadsheet
How do I go about printing the spreadsheet. If I try to print page it just prints what is on the screen. Thanks.
Old Jun 12, 2019 | 09:33 AM
sddesigns's Avatar
sddesigns
FTE Leadership Emeritus
FTE Emeritus
try this one here... Google Docs FORScan
Then select file print
Old Dec 13, 2025 | 09:50 AM
Deibi1016's Avatar
Deibi1016
1st Gear
Information
hello, I am new here. I need help with add remote start in my 2020 ford f150 supercrew 5.0, I installed all modern the antena everything, change the 4 inch radio for a 8 inch radio but When I go to fordpass I do not have the option of remote start... need some help please.
Thank you.
Old Dec 14, 2025 | 06:30 AM
Kyle23u's Avatar
Kyle23u
2nd Gear
Thank you.
Might want to try reading this thread. https://www.ford-trucks.com/forums/1...e-with-it.html
Basically not possible without the TCU or such bc i think that is the connect module and then aswell it needs a 4G modem for cell service otherwise there isnt any way for fordpass to work or connect. And then also check if you got everything in forscan right.
I'm also trying to get remote start(on a 2017 XLT) just with the key fob first and then im going aftermarket due to fordpass I believe is subscription based after while and I've installed remote start on another car before and like its system(compustar cm900 with the drone mobile)
StrokinHer01
Nov 6, 2019 05:55 PM
JSfray
Jan 7, 2019 09:05 PM
2017F250Diesel
Dec 11, 2018 09:55 AM
Todd Swing
2015 - 2020 F150
Sep 8, 2018 09:41 PM
StrokinHer01
Jan 26, 2018 09:23 AM
