New Connection betjene transmission and rear Axle
How Will i find the length of the Connection axle (what du you call the axle) between transmission and rear axle. My question is when i stick the yoke all the way in to the transmission how long du i have to pull yoke out i have been told 25 mm, before i can measure the length. What is your opinion
Here is a link to a diagram that shows how to measure for a driveshaft.
http://azdriveshaft.com/wp-content/u...02/D1_2017.pdf
Slip yoke clearance should be 3/4" to 1" to accommodate suspension travel.
This site or any driveshaft shop should be able to help you with the proper length driveshaft-
Dennys Driveshaft FAQ Page Frequently Asked Questions and Answers
You may want to find a shop that specializes in making driveshafts. I think that Shaftmasters is a national chain. They will tell you what measurements they need. Also if you have a combination other than OE you might need to tell them the date code off the tag on your rear axle and the serial number off your transmission.
I just purchased and installed a new driveshaft from denny’s Driveshaft and I highly recommend them. Use their printouts online to measure the distance between transmission and rear end and send them in. It takes about 3-4 weeks but it’s worth the wait. It took longer to unbox it than it did to install.
If if you get in their waiting list and pay the $100 deposit you will get $10 off your order.
cajohnson
09-01-2018 05:18 PM
usuallybowtie
06-06-2016 12:39 PM
