Certification Label Codes
Old Feb 9, 2018 | 11:48 PM
Hubby's Avatar
Hubby
Hi,
I just joined today. I went through a lot of VIN and certification label code threads but was unable to find how to decode either. I am most interested in the Transmission (whether Mazda or ZF) and in the axle gear ratio. If anyone can decode the VIN and cert label I would appreciate it much. Can you tell the difference between Mazda and ZF by looking at them?
I have a 1994 F150 regular cab 4.9 4x4 1FTEF14Y6RNA83783. The certification label reads
WB "133"
TRANS "M"
AXLE "H9"
TYPE-GVW "F142"
BODY "B64"
TRANS "M"
AXLE "H9"
TAPE
SPRINGS "K I"
Thanks
Old Feb 10, 2018 | 12:09 AM
roboto65's Avatar
roboto65
General Information
MFR model code F14
Body type:
Pass Doors: 0
Alternative name:
Alternative body:
Drivetrain:
Original Pricing
MSRP $16,733.00
Invoice $14,378.00
Destination Charge $600.00
Engine & Powertrain
Type Straight 6 Cylinder Engine
Displacement L/CI 4.9/300
Fuel Type Gasoline Fuel
Horsepower @
Fuel Economy 0.0 City / 0.0 Highway
Fuel Capacity 0.0
Net Torque @
Tech Specs
Manufactured By United States Ford
Mazda M5OD Transmission
H9 83/ 3.55 3.75M Ford Limited Slip
H9 87/ 3.55 3.8M Ford
Old Feb 10, 2018 | 01:49 PM
Hubby's Avatar
Hubby
When I returned to the post the VIN was hilighted for decoding. When I clicked it said the axle is 3.08 and I couldn't see where the Mazda transmission was mentioned. Why do you say 3.55? Where do you see the Mazda?
Old Feb 10, 2018 | 01:56 PM
Mudsport96's Avatar
Mudsport96
Well easiest way to know it's the Mazda m5od is because it is a 150. The zf5 only came in the 250/350 chassis.
Old Feb 10, 2018 | 02:37 PM
Conanski's Avatar
Conanski
Check this link.. https://www.ford-trucks.com/articles...le-code-chart/
Old Feb 10, 2018 | 04:52 PM
Hubby's Avatar
Hubby
Thanks much for the reply. I guess everyone knew that about the ZF but me.. Did all 250/350 5-speeds have them?
Looking at the axle code chart it says H9 3.55 1991. Does that mean 1991 and years following? What does limited slip do? I think I read you have to add something to the grease - what is that?
Old Feb 10, 2018 | 05:07 PM
Conanski's Avatar
Conanski
No, both my '89 and '90 trucks has the same axle code, I suspect the 1991 reference just signifies the source date of the data.
It is a type of differential that limits the amount of slip between both wheels on the axle. A friction modifier additive is used to smooth the gripping action of the clutches contained in the differential.
Old Feb 10, 2018 | 05:35 PM
Ddaybc's Avatar
Ddaybc
My 1994 in my sig has the H9 axle code and it's a limited slip 3.55 axle ratio so that's what you have in yours.
awhtx
Large Truck
Aug 20, 2010 10:11 AM
BikeMaker
Large Truck
Sep 21, 2009 04:17 PM
zpmps2
Dec 31, 2007 09:08 AM
SickPuppy
May 20, 2007 12:27 PM
WillyB
May 19, 2005 12:20 AM
