Vin and Product Code, Please help.
Old May 18, 2005 | 03:14 PM
WillyB's Avatar
WillyB
I am trying to decode the data on a truck I bought. Originally I was going to use it as a donor truck for my 1959 project, however, I sort of like the way it drives.
I looked at the decoder in the trans and axle articals, but it was not very helpful. I have an axle code of 12, which it shows as a Ford axle with a 2.73 ratio, but lists it for a 1991 truck. My truck is an 87.
My trans code is "k", which I think is a C6, but the "k" code is not even listed for a 87 and up truck.
If I keep the truck as a driver I will buy a manule, but for now would someone mind looking up the codes for a '87?
My type is "F151"; my body is "BD4"; Trans is "k"; axle is "12"; and springs are "v" and "h".
The Vin is 1FTCF15Y2HPA64754.
Thanks for the help - and please post a link if there is a reliable code reader on the net ----
WillyB
Old May 18, 2005 | 03:59 PM
bobcf's Avatar
bobcf
VIN: 1FTCF15Y2HPA64754
World Manufacturer Identifier - 1st, 2nd, 3rd Positions
VIN Code: 1FT
Assembly Country: USA
Make: FORD
Body Style: PICKUP
Restraint System Type (Passenger Cars) or Brake Type and GVWR Class (Trucks and Vans) - 4th Position
VIN Code: C
Brake System: HYDRAULIC
GVWR Class: Class C:
Restraint:
GVWR Range: 4,001 - 5,000 POUNDS
Line,Series Body Type - 5th, 6th, 7th Positions
VIN Code: F15
Vehicle Line: F-150
Series:
Chassis Type:
Body Type: REGULAR
Vehicle Type:
Engine Type - 8th Position
VIN Code: Y
Engine: 4.9 LITERS
Cylinders: 6
Fuel: GASOLINE
Engine Manufacturer:
Horsepower: 145 - 150 HORSEPOWER
Model Year - 10th Position
VIN Code: H
Model Year: 1987
Assembly Plant - 11th Position
VIN Code: P
Assembly Plant: TWIN CITIES: ST. PAUL, MN
Production Sequence Number - 12th - 17th
VIN Code: A64754
Prod Sequence Number A64754
Additional Information
Transmission Type
Transmission Manufacturer
Transmission ID
Wheel Axle Manufacturer
Wheel Axles Wheelbase
Old May 18, 2005 | 08:42 PM
WillyB's Avatar
WillyB
Thank you, that was interesting. I have saved that information and will add it to the notebook on the 59 build. Unfortunatly the two items I am most interested in are the trans type and the axle code - "k" and "12" on the paper plate glued to the door pillar. Any help there?
On my '59 the vin plate is riveted to the inside of the glove box door - Two screws and the door is off the truck!
Old May 18, 2005 | 08:52 PM
tex94F250's Avatar
tex94F250
Take a look in the tech section which has codes for transmission and axles.
Old May 18, 2005 | 09:06 PM
WillyB's Avatar
WillyB
Thank you Texas - that area did not help. It did not show the trans code "k" and the axle code "12" was listed as installed in a 91 Ford - mine is an 87.
If it had been that easy I would not be bothering the good people of this board -
Old May 18, 2005 | 11:52 PM
PyroBob's Avatar
PyroBob
trans code "k" = C6
axle code "12" = 2.73, no ls
front springs v = 5310 spring
rear springs h = 5560 spring
Old May 19, 2005 | 12:20 AM
WillyB's Avatar
WillyB
Thanks, everyone. That is all the info I needed. It is exactly what I wanted. I will likely use it as a daily driver this summer and then use the chassis under my '59 when I complete the bodywork on it. It is funny as both trucks came from salt free areas, but the '59 has less rust than the '87.
