Sponsored by: Auxito
Big Dreams
Old Feb 9, 2018 | 09:05 PM
Adrian Arnold's Avatar
Adrian Arnold
Big Dreams
I want a 97-03 F150. but I need advice.
first up. I have devised a plan if the stock engine fails me. I will put in a Dodge Cummins 12 valve and transmission. these swaps have been done. and I have read that youll need a heaver duty axle. i feel like a axle from a 99-04 f 250 or 350 truck. and doing so ill find a dually and make a 97-03 dually f150. then ill take the bed off and make a flat bed. i think with this setup i might be able to do some heaver towing.( i don't tow very much but i want the capabilities) i think this might work.
Second. i want to make a removable 'truck bed sides'. where they are hinged to the side of the bed and can be bolted in a up or down position depending what my needs are.
criticism is very much welcomed.
Old Feb 9, 2018 | 10:22 PM
steve(ill)'s Avatar
steve(ill)
https://www.ford-trucks.com/forums/1...w-longbed.html
Old Feb 10, 2018 | 03:08 PM
Adrian Arnold
I know its possible. but a co worker said the axles might not line up. is this true? and if it is how could you make them work?
Old Feb 10, 2018 | 09:54 PM
steve(ill)'s Avatar
steve(ill)
why take a F150 and put a motor and axles from a F250-350 in it ??? If you need that kind of pulling and load capacity, get the BIG FRAME.
Old Feb 14, 2018 | 09:18 AM
Adrian Arnold
i like the look of the 97'-03'. And im interested if this is possible
Old Feb 14, 2018 | 11:25 AM
Bluegrass 7's Avatar
Bluegrass 7
Get an F250 V10, put the flat bed on and have it over with.
The truck don't look that much different than the 150.
Good luck.
Old Feb 18, 2018 | 10:33 PM
Adrian Arnold
yea. i just want opinions and ideas.
Old Feb 21, 2018 | 09:32 PM
z31freakify's Avatar
z31freakify
A better swap would be a 6.8, the Cummins wet weight is over 1100lb + the transmission, what about the frame? Suspension? Axels? And other nick nacks that will help support that behemoth?
TheNarwhal
May 26, 2017 04:02 PM
kidkyle21
38
Dec 28, 2016 10:08 AM
Freighttrain
All Things Towing
Jan 3, 2014 02:33 PM
markjw
Mar 2, 2007 05:25 PM
NoWake
Sep 18, 2002 10:34 PM
