Engine/trans monitoring system
I don’t really have any desire to have a programmer on my 6.7, but I would like to see actual numbers for some of the critical drive train components. What is a good electronic interface to connect and see temps and pressures for not much money. A quick search on google came up with two edge products. What do you all like and is the best bang for the buck.
I use the same setup. Works great, you can configure the Torque Pro to show you the temperatures for sensors that aren't available on the console. I've got mine setup to show me the 4 exhaust temperature sensors, the Oil Temp, Transmission Temp, the DPF Soot %, and an illuminated On/Off indicator for when regen is taking place. All the stuff a person needs.
I keep seeing everyone who's running the Bluetooth setup with an app on a phone or tablet is the way go. I keep thinking about pulling the trigger on this.
I bought an iDash and am not happy as you only have 5 gauges, have had problems, good customer service though but the Edge would have been the way to go because of more DPF gauges but the Edge is also limited in what you can pull up.
Hey Braggs, not knowing much about Torque Pro... can you pull up the distance between regens also? I also have been reading about FORscan also which a lot of guys run also.
