leaf spring bushings
Old Feb 7, 2018 | 11:13 PM
gostephen's Avatar
gostephen
i am looking at replacing the leaf spring bushings on the front springs
i am trying to figure out what size they are i am looking at energy suspension part numbers 4.2118R or 4.2119R they have 2 different "main eye Diameters" one is 1.25od and 1.5od
how do i measure this
everything is still on the vehicle and i would rather not have to take it apart untill i have the new bushings.
1975 f250, 4x4, ranger xlt, fe390
Old Feb 8, 2018 | 01:14 AM
1TonBasecamp's Avatar
1TonBasecamp
From what they say in the catalog, this is measured on the OD (outside diameter) so in theory at least you should not have to remove the spring to measure the bushing. Sounds like it should be easy enough to check then, if you have a dial or digital caliper set, or similar tool.
I'm not sure why they would list OD as the spec, unless it's just for this reason of making it easier to measure on the vehicle.
Normally they'd be comparing the ID but maybe they're attempting to make it easier on us for once.
So while I don't know if that's all true, it would be easy enough to find out. Just measure the main spring eye with a caliper-like device at the frame end of the spring.
Assuming you can even get a standard caliper in there that is! I've never tried it, so not sure if there's enough room to maneuver in there.
If you've tried it already and it didn't work out, we'll figure something out.
Good luck.
Paul
Old Feb 8, 2018 | 12:32 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
how do i measure this? everything is still on the vehicle and i would rather not have to take it apart until i have the new bushings.
1975 F250 4WD
As original:
C7TZ-5348-A
.. Front Spring FRONT & REAR Bushing & Shackle Bushing - 1/4" O.D. x 37/64" I.D. x 3 3/8" long / Obsolete
High Boys: 1967/76 F250 4WD; 1977 F250 4WD before serial number Y20,001
Old Feb 11, 2018 | 11:31 AM
somethingclever's Avatar
somethingclever
You need to know the bushing OD is 1.5” x3” lg (outer sleeve) to go along with Bills info given above for bushing inner sleeve dimensions.
helm40
Oct 8, 2018 10:09 PM
F-250 WARHORSE
Jan 7, 2017 08:34 AM
302flareside1992
Aug 29, 2016 05:14 PM
jmm
17
Jun 5, 2012 04:29 PM
jgrim23
Jun 13, 2006 08:11 PM
