EFI 460 help
Old May 26, 2018 | 07:45 PM
  #46
84red's Avatar
84red
Well, did some more diagnostics and it appears that cyl 3 and 4 are dead! I also noticed that the issue got worse when I put new plugs and wires in back when I got the truck. Praying on a bad plug wire, or dead injectors or wiring.
Old May 26, 2018 | 08:21 PM
  #47
84red's Avatar
84red
Well, injector harness came up fine for those 2 connectors, as did the ohms for the injectors. Also borrowed high quality plug wires from my 86 f250. NADA. About to give up.
Old May 27, 2018 | 06:52 AM
  #48
vjsimone's Avatar
vjsimone
Do you know the compression of those 2 cylinders ?
Old May 27, 2018 | 05:49 PM
  #49
84red's Avatar
84red
I do not, and I don't have a compression tester... I still think it has something to do with ignition/fuel though because every once and a while it doesn't chug and runs perfect, for about 10 seconds, but still. I know it somewhat changed when I put new plug wires on? Maybe the routing of them is messed up? No idea why they aren't contributing, other than clogged injectors or fried ecm. Will be snatching some JY injectors and cleaning them soon. Will see if there is any difference, and I will see about renting a compression tester. Not the end of the world as it was planned to only be a parts truck that I have been DDing. Guess it might be parts quicker than anticipated.
Oldgreyf250
Sep 20, 2016 04:14 PM
TKegs763
Aug 7, 2013 12:03 AM
geson
Jul 18, 2004 07:11 PM
PeterM66
1978 - 1996 Big Bronco
Jul 18, 2004 04:07 AM
jimmysrangerxlt
1983 - 2012 Ranger & B-Series
Mar 22, 2004 07:03 PM
