Sponsored by: Real Truck
Excursion power steering problem.
Old Feb 7, 2018 | 01:55 PM
Obs7.3Powerstroker's Avatar
Obs7.3Powerstroker
I have a 2001 7.3 excursion 4x4. It’s power steering pump was moaning and it would lose all power steering if you applied the brakes. I replaced the power steering pump ... no change, replaced the hydro boost ... no change, replaced the high pressure line from the pump to the hydro boost and the line from the gear box to the hydroboost ... no change. I also have made sure there is no air in the system to mess it up. It has some power assist when sitting but the pump moans a little, but if you hit the brakes or turn the wheels all the way to lock it will moan really loud. Also when the brakes are applied or the wheels are all the way to lock the pump fluid level drops about about and inch and comes back when the brakes are let off. I am totally lost on what to do next. Any tips or ideas would be greatly appreciated.
Old Feb 7, 2018 | 06:11 PM
DogRidesInBack's Avatar
DogRidesInBack
Really sounds like air in the hydraulics to me.
May take a bit of googling to find the correct bleed procedure, recall reading it takes about 60 passes along with proper application of brakes to get the air out.
Old Feb 8, 2018 | 07:25 AM
Obs7.3Powerstroker
I bled the system for at least an hour and a half going from lock to lock until no bubbles came up the power steering pump reservoir.
Obs7.3Powerstroker
Feb 6, 2018 08:25 PM
Bigjay74
Mar 22, 2016 09:26 PM
dustinsheeler717
Jul 8, 2015 10:44 PM
So_Cal_PowerStroke
Feb 9, 2009 05:49 PM
paulford
Aug 9, 2006 01:01 AM
