Excursion power steering and brake problem!
Old Feb 6, 2018 | 08:25 PM
Obs7.3Powerstroker's Avatar
Obs7.3Powerstroker
I have a 2001 7.3 excursion 4x4. It’s power steering pump was moaning and it would lose all power steering if you applied the brakes. I replaced the power steering pump ... no change, replaced the hydro boost ... no change, replaced the high pressure line from the pump to the hydro boost and the line from the gear box to the hydroboost ... no change. I also have made sure there is no air in the system to mess it up. It has some power assist when sitting but the pump moans a little, but if you hit the brakes or turn the wheels all the way to lock it will moan really loud. Also when the brakes are applied or the wheels are all the way to lock the pump fluid level drops about about and inch and comes back when the brakes are let off. I am totally lost on what to do next. Any tips or ideas would be greatly appreciated.
Obs7.3Powerstroker
Feb 8, 2018 07:25 AM
RussellF
Mar 16, 2014 03:51 PM
Oscarsf3506.0
Nov 20, 2012 06:12 PM
OnTheTrail
May 21, 2007 08:42 PM
paulford
Aug 9, 2006 01:01 AM
