Question about main Bearings:
Old Feb 7, 2018 | 10:08 AM
F-250 restorer's Avatar
F-250 restorer
Hello. I seem to have found the limitation of my usual forum, and so I came here looking for answers.
I'm looking for main bearings for a 1975 inline 300 block. The size is standard. When I looked on Rockauto, I found they show two diff. flange sizes: 3.5670 diameter, and 3.602 od. That is .035" diff., same year, all standard. Does anyone know why? or what they are referring to with 'flange?'
Old May 31, 2018 | 12:53 PM
Boiler Guy's Avatar
Boiler Guy
Rock auto should know.
Old Jun 1, 2018 | 11:35 AM
baddad457's Avatar
baddad457
The larger diameter is the outer diameter as it states. The other is the inside diameter, the crank journal should be a few thousandths smaller still. Measure the diameter of the crank journal and the diameter of the circle the bearing shells fit into with the main caps installed and torqued to spec. This will tell you if these are the correct bearings for your engine
Old Aug 17, 2019 | 07:00 PM
Bdox's Avatar
Bdox
The "flange" term makes no sense to me.
Look to a regular Ford dealer for the parts, it might all become clear.
Or look up "Numberdummy" here on the forums, he will explain all.
Old Aug 17, 2019 | 07:40 PM
Tedster9's Avatar
Tedster9
I bet @NumberDummy don't know beans about fluid dynamics or lunar orbit rendezvous using a slide rule!
F-250 restorer
Jul 9, 2015 07:28 PM
dogmantra
Nov 14, 2010 03:04 PM
ksubigbuck
Jun 10, 2008 09:37 AM
burge743
Apr 9, 2006 09:48 PM
redf1001962
Apr 4, 2006 07:28 AM
