main bearings
Old Apr 9, 2006 | 07:51 PM
burge743's Avatar
burge743
main bearings
just disassembled my 460. i have never used plastigage before.almost embarrassed to ask this but, do i need to buy new main bearings to check oil clearance or do i check the clearance with the old main bearings and then decide what size bearings to buy?
Old Apr 9, 2006 | 09:05 PM
Kruse's Avatar
Kruse
No need to be embarassed. Nobody in this forum was a plastigage expert
until they used it. Actually, you can use plastigage on new or used bearings.
It would be nice to know what you are doing to the engine. Are you completely overhauling it, re-ringing it or what? If you completely have the engine disassembled, I would have the crank freshened up, but that's just me.
Old Apr 9, 2006 | 09:31 PM
Bdox's Avatar
Bdox
The plastigauge will tell you the clearance betweent the bearing and the crank. It won't tell you what size bearings to buy. To determine that, look on the back of the bearing for any markings. If there is nothing there, you will have to measure the crank journal diameter. If you are not equipped to do that, pull the crank and take it to an automotive machine shop and let them evaluate it for you. If there is any scoring or ridges on the journals, you will need to get it turned.
Old Apr 9, 2006 | 09:48 PM
monsterbaby's Avatar
monsterbaby
You should have the crank measured anyway if your going through it, that will tell you if you need to have it ground or just polished, and rather there is any taper to the journals.
You can use plastigauge to determine how much clearence you have though to determine if just putting new bearings in would be enough.
Just remember plasitigauge is a pretty rough measurement, so if this is a hi performance application using GOOD mics, and inside mics to measure the exact difference between teh bearings and the actual journal is the only way to get a precise measurement but most street builds don't need that type of accuracy.
sickpup2
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
Jun 25, 2020 04:35 AM
jeff14346
15
Oct 2, 2011 10:36 PM
73 ford guy
Aug 5, 2008 09:43 PM
Ratsmoker
Oct 16, 2001 03:00 AM
