Oil burning
Old Feb 6, 2018 | 07:42 PM
PurpleSageEquine's Avatar
PurpleSageEquine
Oil burning
My '97 7.5l startd burning oil during a trip and running extremely rough. When I pulled the plugs one of the plugs was extremely oil fouled. What is the cause is it a hard fix. Also the front end shaking my teeth out just started suggestions needed.
Old Feb 7, 2018 | 10:12 AM
Ddaybc's Avatar
Ddaybc
If your engine started burning oil suddenly it can be a number of things. To begin with, keep it simple. Check to see if you have any codes.
Next, it may simply be a bad plug or plug wire. Swap the plug wire with another one and if it fixes the problem you know what it was. Of course change or clean the oiled plug first. If the truck hasn't had a full tune up in a while I would start with that anyway. New rotor, distributor cap, plugs, oil and air and oil filters. If the plug wires are original I would change them too.
If that doesn't fix the issue you will need to consider something has gone awry inside the engine. Ie: valve seal, broken or stuck ring. I've even seen a piston with a tiny hole in it do the same thing. A compression test and a leak down test will give you a good idea of what may have happened.
Old Feb 7, 2018 | 02:27 PM
J ballan's Avatar
J ballan
Do a compression test on the hole with the bad plug while your changing it.
Old Feb 7, 2018 | 05:30 PM
PurpleSageEquine
I did do a complete tune-up including distributor cap and new plugs and check the wires. Did not fix the problem. Low compression in that cylinder. Just trying to find out what the problem maybe and if anybody has an idea if they have to pull the motor to fix it.
Old Feb 7, 2018 | 07:29 PM
J ballan's Avatar
J ballan
Most likely yes you will. At a minimum the heads will need to come off and that can be done with the engine still in the truck.
ajaxel
Jun 2, 2013 03:29 PM
chadfitz
Modular V8 (4.6L, 5.4L)
Apr 16, 2010 06:46 AM
btorear
May 16, 2008 02:50 PM
Shep VA
Mar 14, 2008 07:03 AM
chsw
3.0L V6
Sep 21, 2005 07:08 PM
