spark plug fouling question
Old May 13, 2008 | 09:08 AM
btorear's Avatar
btorear
I have a 1974 f 100 with a 302. I bought it last weekend. It ran very rough, backfiring, stalling, engine quitting at stops, etc... changed the plugs and plug wires, distributor cap and rotor when i got home. one plug (for the number 3 cylinder) was fouled with caked up with a lot of black soot. Changed the plugs out and ran it a couple of days. pulled the new plug out from #3 and it's all black with soot too. Any idea what could be causing this? The other plugs look good, it's just this one. I would really appreciate any help anyone can offer, thanks in advance.
Old May 13, 2008 | 09:57 AM
beartracks's Avatar
beartracks
It could be that there is a problem with the ignition firing that particular plug, i.e. a bad plug wire etc. However the more serious possibility is something like a broken ring or piston. I'd try to do a compression test and resistance test the wires.
Old May 13, 2008 | 10:02 AM
NOCO77's Avatar
NOCO77
Sounds like #3 cylinder has issues - bad valve seal, guide or crack(s), bent/burned valve, bad/broken piston rings, etc., or some combination of this. I would suspect a fuel delivery issue except you say that the other 7 plugs look ok, so there is a compression problem in that cylinder. When the engine is under a slight load, does it have a miss (studder, stumble,etc.)?
Old May 13, 2008 | 10:32 AM
btorear's Avatar
btorear
Yeah, under a slight load it will spudder and cough a little.
Old May 13, 2008 | 07:59 PM
flcracker9's Avatar
flcracker9
You need to test for spark in that cylinder. If that checks ok, run a wet and a dry compression test on all cylinders. This will give you an idea of the condition of your motor. Could be something simple like a valve seal or guide, or could be rings. The test should narrow it down.
Old May 16, 2008 | 10:17 AM
btorear's Avatar
btorear
ok. i did the compression tests last night. the cylinders read like this 1=120, 2=120, 3=110, 4=120, 5=140, 6=140, 7=120, 8=125. since #3 was the lowest i did a wet comp test, and it jumped up to almost 150. does this definitely tell me it's the rings, or is there still a possibility it could be something else? also, is there another test i could do to narrow things down? Any help is greatly appreciated.
Old May 16, 2008 | 11:46 AM
tractoman's Avatar
tractoman
I think that is an indicator of bad rings. You could do a leakdown test to confirm this but normally the wet test allows the rings to seal better and raise the compression.
Old May 16, 2008 | 01:03 PM
beartracks's Avatar
beartracks
Keep in mind to get acurate compression numbers you should block the carb wide open (disconnet the ignition!) and remove all the plugs before starting. Yes, a jump after adding alittle oil indicates worn rings but your numbers have a pretty wide spread.
Old May 16, 2008 | 02:42 PM
btorear's Avatar
btorear
Yeah i had the ignition wire off and all the plugs out. What do you mean it's a pretty wide spread? Could that mean something else other than worn rings? You can probably tell, but I'm very much a novice.
Old May 16, 2008 | 02:50 PM
wedefyu's Avatar
wedefyu
It could mean an engine rebuild is in order...
brickyiowa
Jun 22, 2012 10:28 PM
re_fill
1978 - 1996 Big Bronco
Oct 21, 2006 12:56 AM
lost_in_space
16
Mar 5, 2005 05:03 PM
AQUARIES1
13
Mar 1, 2004 06:49 AM
webby
Oct 22, 2000 11:15 PM
