C6 Kickdown Rod
Old Feb 6, 2018 | 02:34 PM
Henshaw's Avatar
Henshaw
C6 Kickdown Rod
So I bought my truck, kickdown rod was hooked up. The other day I'm riding and I noticed it didn't want to down shift anymore. So I check, and the rod isn't hooked up anymore. It survey came loose. So my question is, where does it attach on the carb? I have the original two barrel moto/auto craft carb.
Old Feb 6, 2018 | 02:47 PM
mrollings53's Avatar
mrollings53
I'd imagine it is determined by what engine you have.
Old Feb 6, 2018 | 02:59 PM
Henshaw's Avatar
Henshaw
Lol, that's true. 360fe. I'm assuming it goes on this stud that's on the left side of the throttle., but when I put it on there, the engine is being held open after acceleration.
Old Feb 6, 2018 | 07:22 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
C6: 1968/72 F100/250 2WD & F350 360/390.
Upper pic: Kick down rod is 7A187
Old Feb 7, 2018 | 12:21 PM
JEFFFAFA's Avatar
JEFFFAFA
Here is an example pic I found. The kick down rod is yellow in this pic.
Old Feb 7, 2018 | 12:29 PM
Henshaw's Avatar
Henshaw
Yeah, that's what I thought, but when I pin it there my throttle sticks now... guess I gotta replace that horizontal spring. I'll spray with with some wd40 and see if that helps for the moment.
Henshaw's Avatar
Henshaw
Thank y'all, btw!
Old Feb 7, 2018 | 12:41 PM
JEFFFAFA's Avatar
JEFFFAFA
No. Don't use WD40. (water displacement...40th try) Only carb spray cleaner should be sprayed on carb and choke linkage.
Note. If a carb to intake manifold spacer was installed the trans kick down rod will now be too short.
Old Feb 7, 2018 | 01:11 PM
Henshaw's Avatar
Henshaw
It's completely stock. No spacer. It outta work once I lube her up.
Old Oct 25, 2018 | 07:35 PM
coloradotrk's Avatar
coloradotrk
I have changed Carbrator to a holly 2 barrel. Do you know or know where I cand get the bracket for the carb ?
jesse howell
Apr 7, 2020 05:34 PM
White Boy
Dec 25, 2012 09:22 PM
biggut
Sep 17, 2009 07:02 AM
DNewton
Feb 9, 2007 09:35 PM
alankirby
Apr 5, 2006 06:09 PM
