C6 kickdown rod
Old Feb 9, 2007 | 06:55 PM
DNewton's Avatar
DNewton
C6 kickdown rod
i ran into a very crappy problem today, while installing my motor, and wiggling it around, i bent my kickdown rod, now when i manualy fuel the ip, the kickdown rod does not move whatsoever, what should i do? i know that its got to be in the right place, and i dont want it meesing up my trans if i adjust it to ware it will move......
Old Feb 9, 2007 | 07:03 PM
Winger235's Avatar
Winger235
I would just take it off. My truck used to pound through gears if you matted it. My brother in laws rusted off. With the RPMs these things have it is almost a joke they are on there. Mine kicks down just fine without the kick down rod and it is not forced and pounding. If I want to be in another gear I just pull the lever down.
Old Feb 9, 2007 | 07:18 PM
typefour's Avatar
typefour
The c6 will not be damaged by running wothout it, the pressures are set by the vacuum modulator. if you remove the kickdown rod you way not even know its missing!!!
Old Feb 9, 2007 | 07:43 PM
Winger235's Avatar
Winger235
Been running mine without one for many years it was a nuiscance when it was there.
Old Feb 9, 2007 | 09:35 PM
Spectramac's Avatar
Spectramac
You could just bend it back around to where it will move unless it's a lost cause. If you were closer I have a bunch of them laying around from turbo-ing them over the years.
They just need to take out almost all the play out of the lever at WOT.
djmichael24951
Sep 23, 2013 06:18 AM
White Boy
Dec 24, 2012 11:30 AM
684rd
Feb 7, 2001 06:06 PM
684rd
Feb 2, 2001 06:04 PM
