E4OD oil
Old Feb 6, 2018 | 12:12 PM
bart f-350's Avatar
bart f-350
E4OD oil
Hello,
In my 1989 F350, I have a E4OD gearbox, I like to change the oil, and found an oil to this specification, could that be a good oil to use?
Ford Mercon/M2C138-CJ/166-H
And is it correct that the same oil goes in the transfercase?
Thanks
Old Feb 6, 2018 | 01:10 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
Yes, that's kinda the right fluid.
When the E4OD was designed that was the fluid specification. Ford discontinued this spec in 2006 and changed MERCON V to be compatible with the E4OD and other transmissions that used MERCON. MERCON V is now specified for the E4OD.
*IF* that fluid meets that spec then it's fine to use it. However, MERCON V is a better fluid and I recommend using it.
Old Feb 6, 2018 | 03:29 PM
bart f-350's Avatar
bart f-350
Ok, that leaves my question if this fluid also goes into the transfer case?
Thank you.
Ps I found one wit this spec (I'm sorry, those spec's don't really speak to me) would that be ok?
Ford M2C33-F/G
Ford M2C9007-AA
Old Feb 6, 2018 | 04:43 PM
Mark Kovalsky
I don't know about the transfer case.
therigwelder
Nov 12, 2014 07:40 PM
f1501987
Nov 24, 2012 10:58 PM
CRICKEYDOG
1997 - 2003 F150
Feb 3, 2010 08:01 PM
danlee
Oct 21, 2009 06:45 AM
reets001
Jan 24, 2006 03:49 PM
