E4OD Chatter
Old Jan 22, 2006 | 08:53 AM
reets001's Avatar
reets001
E4OD Chatter
I have a 95 F-150 4x4 with the E4OD Trans. When it shifts into od the trans. chatters real bad. I changed the fluid about a year ago and put the additive in and it worked well. I work this truck hard pulling a horse trailer and am thinking of changing the fluid again. Can you tell me what in the best fluid to use and do I have to use the additive with it? Seems I read here some time ago of a mercon 6? Any tips?
Old Jan 22, 2006 | 07:50 PM
Casey's Avatar
Casey
MERCON/DEXRON III is the correct fluid. There are MERCON V and MERCON SP fluids, but they will kill the E4OD.
Use a synthetic MERCON/DEXRON III and no additives.
Change the fluid with THIS method to change all the fluid. What's in the pan is less than half of the total.
Old Jan 23, 2006 | 03:57 PM
reets001's Avatar
reets001
Thanks for the info Casey.
Old Jan 24, 2006 | 10:16 AM
tuekwik's Avatar
tuekwik
If you decide to use an additive, I've heard that the Lucas additives work good.
Old Jan 24, 2006 | 03:42 PM
goblue1126's Avatar
goblue1126
i have a e40d tranny that i am going to try and rebuild its two wheel drive i was wondering if anyone had any info. that would help.
Thanks.
Old Jan 24, 2006 | 03:49 PM
goblue1126's Avatar
goblue1126
email is goblue1126@yahoo.com
Thanks again
