Fuel filter change.
Old Feb 6, 2018 | 05:27 PM
backtrack2015's Avatar
backtrack2015
Originally Posted by troverman
The connectors are finicky on the under hood filter but you can figure it out. I started underneath the truck.
Dont worry about a fire. Diesel is not highly volatile like gas.
Thanks for the help. I guess I’ll go order the filters since the time is coming up quick.
Old Feb 6, 2018 | 06:37 PM
troverman's Avatar
troverman
The connections at the filter are low pressure. On this truck, the exhaust manifold is in the vee...fire danger from fuel coming out of the filter area seems very low
to me. Not saying it isn’t possible, but seems unlikely.
Old Feb 6, 2018 | 08:26 PM
kho6658's Avatar
kho6658
I replace mine a couple of weeks ago. First time for me and watched a youtube video first Maybe got two quarts from the water separator and then replaced the one under the hood. Primed it 8 times before starting. Filters ran $95 from the dealer and took more time to drain the water separator than it took to replace both filters.
Old Mar 25, 2018 | 09:24 AM
backtrack2015
I'm in final prep for my first fuel filter swap (15K miles). Anyone remove the cable from the negative battery terminal first? The only reason I can think to do so would be to eliminate the chance of the in-tank fuel pump from starting-up while things are open. I don't see any reason for the pump to start-up but disconnecting the negative battery was part of the boiler-plate Ford workshop manual procedure. Thanks.
Old Mar 25, 2018 | 01:06 PM
troverman's Avatar
troverman
No need to disconnect the batteries. Nothing will happen. Filter change is extremely straightforward.
Old Mar 25, 2018 | 01:54 PM
backtrack2015
Thanks. I went ahead and started by swapping the engine-mounted filter this morning. That was incredibly easy as you have said. I decided not to pull the battery cable.
As for the coalescing filter, it seems I'm siphoning my tank (I drained out close to a gallon with no reduction in rate). My truck is a 7/20/2017 build so I thought I'd be able to avoid this. I'm going to run it down to a quarter tank and try again on that one here next weekend. If the lower tank level doesn't work I'll probably try breaking the vacuum by pulling the inlet connection on the engine-mounted filter. I'm not too keen to be pulling connections above the tank where I can't see all that well.
Old Mar 25, 2018 | 03:12 PM
kcwolf200's Avatar
kcwolf200
I just did mine this past week. Started down below and drained the water separator first. I got about a 1/2 gallon before it stopped. After that, it was pretty easy. I did not siphon out the fuel tank. I read somewhere that you should let the truck cool off after driving, as this will lower the pressure in the fuel system, but I can't remember where I saw that. My truck has a 9/16/2016 build date BTW.
Old Mar 26, 2018 | 04:05 PM
CarterKraft's Avatar
CarterKraft
Maybe a easy solution would be to remove the fuel cap first to release any pressure in the tank.
I know it's probably vented but often the vent will hold positive (" of water pressure) on the tank.
Old Mar 26, 2018 | 04:38 PM
backtrack2015
Possibly. I think I read that for the 2018s (owners manual maybe) you're supposed to ensure the fuel cap is closed (to establish a vacuum on the tank side). Regardless, I expect attempting it at 7/8 full wasn't the best plan. I'll try again here in a few days. I'm just thrilled with how easy it was to swap the engine-mounted filter. That's a big money saver and super easy. It's great that we can do these routine maintenance things ourselves so easily. I'm really liking that aspect of owning this truck.
Old Mar 27, 2018 | 08:58 AM
Texmudder's Avatar
Texmudder
Mine was siphoning. My fix was to remove the fuel cap and it stopped.
Old Mar 30, 2018 | 03:47 PM
backtrack2015
Just to follow up: I tried opening the fuel cap and draining the separator at 5/8 full in the fuel tank (it still siphoned). I then dropped the fuel level down to 1/2 tank (via more driving this week) and when I tried again today it still siphoned. Then it occurred to me that maybe my Stant locking fuel cap might not be allowing much of a vacuum to form in the tank. I swapped back to the OEM fuel cap and viola the siphoning stopped. My hypothesis is the spring is a bit stiffer in the OEM fuel cap which allows a slight bit more vacuum in the tank before opening... just enough to prevent the siphoning. My hypothesis could be dead wrong but I thought I'd share my experience. The filter change was again very easy. Thanks for the help.
Old Mar 30, 2018 | 07:50 PM
CarterKraft
Good to know, at least it gives us something to try.
Old May 10, 2018 | 09:34 AM
  #28
JasonB1's Avatar
JasonB1
OK, I find this thread yesterday after I drained about 5 gallons out of the tank!
I did get the under-hood filter changed with no issues.
Early build truck, after I found the thread, I disconnected the lines under the hood; still siphoning.
I have about 3/4 of a tank in it now. I will run that down to 1/4 and try again. When I do, I will remove the cap to see if that helps.
Old May 10, 2018 | 09:54 AM
  #29
cecilt's Avatar
cecilt
Where is best place to buy the fuel filters? tks
Old May 10, 2018 | 09:56 AM
  #30
JasonB1's Avatar
JasonB1
Amazon had the kits for around $62.
natpark
May 13, 2018 03:18 PM
DW McCall
May 7, 2017 10:25 PM
JonArmy
Aug 27, 2011 11:28 PM
dcciie251
2004 - 2008 F150
13
Jun 1, 2011 10:39 PM
teatowej
21
Jul 23, 2005 11:38 PM
